New Topic New Reply
Author: Subject: Westfield whats it worth
adam1985
posted on 1/6/18 at 08:08 PM Reply With Quote
Hi all im after a little advice, long story short i may be looking at a westfield and want some advice what to look for and possible prices.
Westfield sei wide 1.6 16v 4age about 20 years old was for sale 2-3 years ago for 5.5k but never sold and has been under a tarp ever since and not turned over etc.
Ive seen a picture of it and it DID look a nice car but am going to meet the owner to take a proper look at it.
It is road registered on q plate and has been hill climbed
Obviously chassis condition is going to be one of the main things to check, and im thinking anything else can be replaced if needed but cost will have reflect this.
What are these engines like?
Any ideas of rough value?
CosKev3
posted on 1/6/18 at 08:21 PM Reply With Quote
Under a tarp is not good for seven type cars if it's outside.
If it needs a full strip down and chassis/wishbones refurbishing I reckon 2500-3000 depending on spec of parts fitted,brakes/coilovers etc.
If it doesn't need to go back so far to refurb chassis circa 3500.
adam1985
posted on 1/6/18 at 08:59 PM Reply With Quote
Thats what i was thinking to be honest, any ideas on those engines? Are they well suited to a 7?
CosKev3
posted on 1/6/18 at 09:03 PM Reply With Quote
Never used one myself, but IIRC they are good in a seven yeah.
Light and rev highly
Another thing to consider is if engine is seized/stuck,those prices I put above were if the engine turns freely, if not look at getting it for quite a bit less
adam1985
posted on 1/6/18 at 09:16 PM Reply With Quote
Brilliant thanks for the help, will update this post once i know more
Angel Acevedo
posted on 2/6/18 at 03:07 PM Reply With Quote
Have you checked on Build Diaries the guy thats restoring one, he lists expenses and time in his Youtube videos.
russbost
posted on 2/6/18 at 04:50 PM Reply With Quote
The 4age is a great engine, tho' a little heavy, they rev to around 7500 which is phenomenal for a standard car engine, if it's using the original Toyota alternator there's every chance it will have seized, it's something they were quite prone to even when in regular use, if that's the case then obviously the engine will not turn easily & if it does start you'll very quickly have a smell of hot rubber & a knackered belt! If the engine isn't spinning over freely, just get someone to crank it while you watch the alternator pulley to see if it's spinning
If it's been outside under a tarp it's gonna have plenty of surface rust on any exposed steel & likely mildew probs with seats/trim etc., anything wooden is likely to have warped, you could get yourself a bargain, or you could buy a bucketload of trouble, needs a careful look over
owelly
posted on 3/6/18 at 12:21 PM Reply With Quote
And check the V5!! Make sure it accurately describes the Westfield!!
http://www.ppcmag.co.uk
New Topic New Reply
