Author: Subject: Fog light / brake light separation
craigdiver
posted on 14/8/18 at 02:55 PM Reply With Quote
IVA manual states “Min separation distance from stop lamp 100mm”.
Is this from the centre of the lights or outer edge to outer edge? if it’s outer edge to outer edge then ill need to fit separate fog for IVA as mine is probably too close.
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Abarth 595
Classic Fiat 126 aircooled
Aprilia Mana 850
Kia Picanto
loggyboy
posted on 14/8/18 at 03:33 PM Reply With Quote
Its in the manual.
Rear Fog Lamp to Rear Brake Lamp separation distance must be
measured between the “illuminating surface” of each lamp. “Illuminating
Surface” should be taken to be the area of the “reflector” to the rear of
the bulbs.
Where lamps are mounted in a common housing and are “E” marked,
the separation criteria should be assumed to be met.
[Edited on 14-8-18 by loggyboy]
craigdiver
posted on 14/8/18 at 04:45 PM Reply With Quote
thanks for the info loggyboy, ill need to add a fog light on my rear panel for the IVA. As per photo below the four lights have a side-light halo, outer lights have indicator and brake, inner lights have both fog and reverse. Was just planning on using fog on O/S and reverse on N/S. All four lights pointing directly to the rear.
Abarth 595
Aprilia Mana 850
Kia Picanto
Schrodinger
posted on 15/8/18 at 08:15 AM Reply With Quote
If the car is going for IVA, take the number plate off, or you may get done for no tax,mot or insurance among other things.
Keith
craigdiver
posted on 15/8/18 at 08:47 AM Reply With Quote
thanks, it was only on there temporarily so I could get the number plate lights in the right position. Think I would get stopped pretty quickly - doesn’t look much like the donor BMW now!
Abarth 595
Aprilia Mana 850
Kia Picanto
Schrodinger
posted on 15/8/18 at 03:35 PM Reply With Quote
Where will you be taking it for the IVA?
Keith
gremlin1234
posted on 15/8/18 at 04:01 PM Reply With Quote
do those lights have reflectors built in? or do you need to add some
craigdiver
posted on 15/8/18 at 05:27 PM Reply With Quote
Actually got no idea, anyone know where the IVA test stations are in east central scotland? I live in Fife, nearest city is Dundee but Edinburgh not too far either.
Abarth 595
Aprilia Mana 850
Kia Picanto
craigdiver
posted on 15/8/18 at 05:29 PM Reply With Quote
still got to add a couple of reflectors next to the lights on the rear wings as my numberplate lights reflectors don’t meet IVA spec.
Abarth 595
Aprilia Mana 850
Kia Picanto
