Author: Subject: Clock/gauge mounts
Gracie89
posted on 25/5/20 at 05:44 PM Reply With Quote
Clock/gauge mounts
Hi, does anyone have any spare gauge mounts/clamps they want to sell? I need one 85mm and two 55mm I believe the sizes are. These are the u shaped clamps that mount behind the gauge and two nuts to hold them in place.
Thanks in advance.
gremlin1234
posted on 25/5/20 at 06:24 PM Reply With Quote
Thanks in advance.
if they are nice simple brackets, can't you make some?
Schrodinger
posted on 26/5/20 at 07:33 AM Reply With Quote
You could try https://www.etbinstruments.com/index.php?route=common/home
I have found them helpful in the past
Keith
Aviemore
steve m
posted on 26/5/20 at 08:28 AM Reply With Quote
The attached pic from ebay, show how easy they are to make, and that is what I would do, with
some 10mm/3mm alui bar,
I do have the original brackets, but will only sell with all the gauges, once this lockdown finishes
https://www.ebay.co.uk/itm/NOS-Smiths-Jaeger-2-Gauge-Bracket-Jaguar-MG-Triumph-Lotus-Lucas/254536968477?hash=item3b4395e91d:g:u3gAAOSwJxVc-KWj
posted on 27/5/20 at 07:00 AM Reply With Quote
Make them!
Bit of Aluminium strip, cut to length, drill holes and bend ends - done
Cheap as chips and IMHO easy work.
[Edited on 27/5/20 by nick205]
