New Topic New Reply
Author: Subject: Mounting a JAW AFR display?
posted on 21/6/08 at 09:08 PM Reply With Quote
I'm looking for some bright ideas...
At the moment I'm having to tape the display module from my JAW AFR meter to the top of the dashboard...
JAW display 2
JAW display 2
JAW display 1
JAW display 1
The JAW is only for occasional use, but it does look untidy and doesn't stay where it's put very well.
Can anyone think of a better idea for temporary fixing? I was wondering about something magnetic (the scuttle's covered in steel sheet) but it would have to be something that wouldn't scratch the paint.
cheers,
RichardK
posted on 21/6/08 at 09:12 PM Reply With Quote
aquarium suckers?
just a thought
Rich
Gallery updated 11/01/2011
paulf
posted on 21/6/08 at 09:27 PM Reply With Quote
I dont have a display for mine yet but I datalog using megasquirt software.The JAW has a facility for logging so maybe you would be better off to use that and then review the logs when not driving ,I find it very difficult to watch and interpret a gauge and drive fast at the same time.You could connect the datalog header on the JAW to give a log of revs and maybe add a second tps for the load .
Could you use some adhesive backed velcro for mounting the display? I use it to retain the pda that i datlog with on the dashboard.
Paul.
Howlor
posted on 21/6/08 at 09:33 PM Reply With Quote
How about one of the universal mobile phone sucker mounts?
posted on 21/6/08 at 09:34 PM Reply With Quote
The next version of the Megajolt firmware should have an input for external data (e.g. from the JAW), so that's what I'll do when that arrives (imminent).
Until then I just wanted to get the car into a drivable state, initially to see why the engine was dying on full throttle (now I know - see thread in the engine topic area).
As for velcro - I don't want to put anything permanent on the top of the dash.
Has anyone used that magnetic rubber sheet? If so, how well does it grip?
Mix
posted on 22/6/08 at 06:12 AM Reply With Quote
Hi
The flexible magnetic material I have seen has a rather poor level of attraction, Iwould suggest rare earth metal magnets bonded to the display with the dash contact surface protected with self adhesive vinyl or felt.
Regards Mick
posted on 22/6/08 at 10:44 AM Reply With Quote
Adapt one of the PDA windscreen mounting brackets, should give a very strong mounting without damaging the surface of the gel coat.
Something like this perhaps?
posted on 22/6/08 at 12:24 PM Reply With Quote
Gel coat? Old-fashioned metal here mate!
good suggestion though.
New Topic New Reply
