I almost did something but never even used a tool in anger in the end
bi22le - 21/2/15 at 04:29 PM
Whats that in the sky, sun, dry ground, free time? Quick get out and uncover the car I have stuff to get done!!
Right. First thing to do is bleed the brakes, I have a helper to hand (neighbour) lets crack on.
"what size spanner for the calliper nipple?"
"7mm. Er nope. 6mm. Er nope. Do you have a 6.5mm?"
"An imperial 1/4", I only have metric"
THE END!
big_wasa - 21/2/15 at 06:06 PM
Hmm I emptied the garage to start and have a sort out then the heavens opened so I slung it all back in quick.
The sky's cleared so I tried again. I got the lathe of the trolly I made for it to move house. The heavens opened again so it all was lobbed back in. The end
Dopdog - 21/2/15 at 06:25 PM
I just worked in the garage
HowardB - 21/2/15 at 06:36 PM
I made some small rollers to fix a dyson vacuum cleaner,... not even slightly car related,..
rusty nuts - 21/2/15 at 06:36 PM
I thought about it
emlyno - 21/2/15 at 06:37 PM
Me and the other half took a trip to North Wales, Shrewsbury, Corwen, Bala, Dolgellau.
140 miles, a bit cold, saw some sun, a little snow and just missed a downpour!
First decent blast for a couple of months.
whitestu - 21/2/15 at 06:43 PM
I went for a drive!
The car has sat untouched for the winter despite my upgrade plans.
Still, it started first touch and drove perfectly.
Could do with fitting the heater I bought last year though.
Stu
[Edited on 21/2/15 by whitestu]
fesycresy - 21/2/15 at 06:53 PM
Been there, couldn't find the 1/4" flare spanner. Out came the file and a new Beta 7mm spanner.
Still haven't replaced it, that must have been 8 years ago.
Ben_Copeland - 21/2/15 at 09:55 PM
Dash out the car. Reworking the wiring and sorting out the crap savage switches and their crapper bulbs.
SteveWalker - 21/2/15 at 11:20 PM
I cut tiles to make a "skirting" around the bathroom floor.
I have worked on the car in the garage for a short while a few nights this week though. Pedal box cover off, larger clutch quadrant so that I no longer need to push it so far, rivnuts in so that removing the cover no longer requires me to insert my son upside down into the footwell to hold the nuts while I remove the screws - as an aside, I used to be able to get into the footwell myself, but no longer Cover back on and a bit of a wiring tidy up too.
SPYDER - 22/2/15 at 09:25 AM
I've done the same thing in the past but I started with a 6mm spanner.
garyt - 22/2/15 at 01:46 PM
went out looking at the sky and thought snow that'll be right ... uncovered the car started to play with the wiring and couldn't feel my fingers so covered her back up and came back in, the sleet and wind win .... today
