Ordering prop shaft - what 'ends' do I need to supply?
jps - 1/9/19 at 02:09 PM
I need to order a propshaft for my Haynes, I have heard both Dunning and Fairbank and Bailey Morris well recommended on here, so intend to use one of these.
I have a Sierra 7.5" diff and a Type 3 gearbox - which came from different cars. I do not have the end of the original propshaft which bolted onto the diff, I do have the splined input shaft from the gearbox - which originally bolted to a rubber 'donut'.
Will a prop shaft supplier typically provide the flange which bolts to the diff, and the splined shaft to go into the gearbox - or would I be expected to supply those?
And is there anything else I should know about spec-ing the propshaft (or will need to tell the supplier!)?
rusty nuts - 1/9/19 at 02:24 PM
Bailey Morris supplied all new parts when I ordered my prop .
voucht - 1/9/19 at 03:16 PM
Hi John,
I had my propshaft done by Dunning and Fairbank (from Sierra MT75 gearbox to Sierra 7'' diff.), and they did a very good job. I never heard anything bad about them as well. And they are quick to deliver too. So I definitely recommend them
Provide them with all the informations you have. With their experience, I'm sure they will know what to put at what end.
They definitely have the flange to fit the Sierra diff. I don't know for the splined shaft that fit the type 3 gerabox, but I doubt it will be a problem for them.
For my MT75, I had to get rid of the rubber doughnut, and their propshaft bolts on the Sierra MT75 gearbox tri arm flange via a steel adaptor they provided (with the complete bolt kit). I haven't have to send them anything.
Hope that will help
Eddie1978 - 1/9/19 at 08:00 PM
I used Driveline propa few months ago. type9 to large flange english, all brand new parts painted and balanced £110 delivered to my door 4days from ordering to been in my hands.
Really easy to deal with rang them up told them which ends total length etc... totally painless
[Edited on 1/9/19 by Eddie1978]
