Author: Subject: Speedo needle going a bit crazy
evo.rocks
posted on 29/3/10 at 10:25 AM Reply With Quote
I was out yesterday and when i accelerate (pedal to the metal) the speedo goes mad and the needle starts to rock back and to.
When i accelerate at a normal pace, the needle reads fine up until about 40mph.
Why is it doing this?!?!?
blakep82
posted on 29/3/10 at 10:28 AM Reply With Quote
it it cable driven or electronic?
think the cable one on my old mini used to do that a bit (might have been the rev counter actually...)
________________________
mcerd1
posted on 29/3/10 at 10:29 AM Reply With Quote
what kind of sender have you got and how is it mounted ?
fesycresy
posted on 29/3/10 at 10:30 AM Reply With Quote
The square drive may be rounding off.
Try a new cable.
MK9R
posted on 29/3/10 at 10:34 AM Reply With Quote
if its electrical, mine went nuts just before the battery collapsed.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
evo.rocks
posted on 29/3/10 at 11:04 AM Reply With Quote
its electrical. I have the smithes telemetrix speedo so it picks up the signal from magnets on the prop shaft through the sender.
I just dont understand why its doing it all of a sudden
mcerd1
posted on 29/3/10 at 11:06 AM Reply With Quote
how solid is your sender mounting ? (could it have worked itself loose ?)
I think the magnets on the prop can be a real PITA to get right
[Edited on 29/3/10 by mcerd1]
MK9R
posted on 29/3/10 at 11:11 AM Reply With Quote
thats what i had, i lost a magnet once, i also had an issue with the mounting bracket vibrating so it kept losing the pulse, then when the battery was about to die it went crazy
Cheers Austen
RGB car number 9
www.trackace.co.uk
Xtreme Kermit
posted on 29/3/10 at 11:57 AM Reply With Quote
My speedo and revcounter went nuts once when the earth connection to the chassis came loose.
I would check all your earths first.
posted on 29/3/10 at 04:34 PM Reply With Quote
pah - just stick to 40mph, you'll be fine
