New Topic New Reply
Author: Subject: Corner Weighting Costs
karlak
posted on 12/4/10 at 05:47 AM Reply With Quote
Just after a rough guide to the the cost of having the car corner weighted ?
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
Angel Acevedo
posted on 12/4/10 at 06:04 AM Reply With Quote
Repost...
The cost of 4 bathroon scales...
Plus some scrap steel ans/or wood to build lever arrangements tot bring within scales capacity.
You can even make do with 1 but slow and tedious.
v8kid
posted on 12/4/10 at 07:25 AM Reply With Quote
Yes but is this method even remotely accurate?
karlak
posted on 12/4/10 at 07:31 AM Reply With Quote
OK - Assuming I dont have the scales or necessary skills to correct any problems with the corner weighting. What are the costs for a pro-place to do it ?
Anyone had it done recently ?
ashg
posted on 12/4/10 at 07:57 AM Reply With Quote
normally about £200-250 including setting camber caster ride height etc etc.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
evo.rocks
posted on 12/4/10 at 08:38 AM Reply With Quote
make sure when you have the car corner weighted you sit in the car whilst it is being balanced.
This will give a better balance of the car as it has your weight in it whilst being weighted.
iank
posted on 12/4/10 at 08:49 AM Reply With Quote
Get a an estimate/quote from procomp.
Anonymous
Brommers
posted on 12/4/10 at 08:59 AM Reply With Quote
Or somewhere else. There are plenty of places which can carry out corner-weighting for you. Northampton Motorsport is one place which springs to mind which may not be far away from you.
dhutch
posted on 12/4/10 at 10:41 AM Reply With Quote
Another method is, with a suitably flat floor, use a corner weight gauge such as this one.
http://www.motorsport-tools.com/index.php?main_page=product_info&cPath=13&products_id=1380&zenid=baddc3286f8743e62f0fe03985337e5a
Daniel
Bluemoon
posted on 12/4/10 at 10:52 AM Reply With Quote
If I were to pay-some one to do this I would defiantly call pro-comp first...
Dan
procomp
posted on 12/4/10 at 12:00 PM Reply With Quote
Hi
Cornerweighting only. £25 - £30.
Full setup including full dyno and balancing of dampers. £200.
Cheers Matt
alistairolsen
posted on 12/4/10 at 12:23 PM Reply With Quote
Thats nowhere near as much as I expected tbh! What sort of waiting list do you guys have?
My Build Thread
Steve Hignett
posted on 12/4/10 at 01:46 PM Reply With Quote
Good job I didn't post last night when I read this - I was gonna say that Procomp was £40 and not £30 ish, would have been ripping someone off
New Topic New Reply
