Author: Subject: Rubber Grommet / Isolating bush correct name?
r1_pete
posted on 29/2/12 at 09:44 AM Reply With Quote
I need some rubber grommets, the type which puch into a hole in a panel, take a crush tube and large washers, and are used to isolate components from vibration, usually used with M5 / M6 screws.
Can anyone tell me the correct name so I know what I'm asking for?
Cheers.
Pete.
loggyboy
posted on 29/2/12 at 09:53 AM Reply With Quote
Cotton reel?
http://www.cbsonline.co.uk/product/Cotton_Reel_Rubber_Mount_20mm_Dia_x_15mm_COT1
owelly
posted on 29/2/12 at 10:00 AM Reply With Quote
Like these?
http://item.mobileweb.ebay.co.uk/viewitem?itemId=220938941824&index=4&nav=SEARCH&nid=09545343578
http://www.ppcmag.co.uk
Mopple
posted on 29/2/12 at 10:33 AM Reply With Quote
Maybe "bobbins" is the word to look for.
melly-g
posted on 29/2/12 at 10:35 AM Reply With Quote
Look up memfast and they have things called rubber nut, are they what you mean?
gremlin1234
posted on 29/2/12 at 10:58 AM Reply With Quote
are these what you mean?
http://merlinmotorsport.co.uk/product_info.php?products_id=13790
M6 FEMALE ANTI VIBRATION MOUNT (PACK OF 10)
Rubber anti-vibration nuts for mounting electrical components, dash panels and oil coolers. A rubber nut with EPDM body and a brass insert. Drill the hole; insert the rubber nut: insert screw and tighten;
daviep
posted on 29/2/12 at 11:10 AM Reply With Quote
I think it's something that looks like this you are after Description
Have a look HERE
Also search for "ring and bush mount"
Davie
skov
posted on 29/2/12 at 01:05 PM Reply With Quote
There's various things here that might suit:
http://www.antivibrationmethods.com
r1_pete
posted on 29/2/12 at 09:16 PM Reply With Quote
Thanks for all the leads chaps, I should get sorted now.
