New Topic New Reply
Author: Subject: Creating multiple parts all the same?
posted on 23/4/14 at 06:57 PM Reply With Quote
So, we have the tubemitre.exe for notching tubes but I'm looking for a program I can draw the parts out on and print off, stick on the steel and cut out. Looking at this cause there a either 2x this bit or 4x that bit and I would like to draw once, check then cut, all the same..
Any advise?
Barlidge
posted on 23/4/14 at 07:06 PM Reply With Quote
I use Quark Xpress or Adobe Illustrator.
Build Diary: http://www.roadster-builders.co.uk/forum/viewtopic.php?f=25&t=111
Irony
posted on 23/4/14 at 07:45 PM Reply With Quote
Quark is best to be avoided at all costs. In fact I haven't met a quark user in 10 years!
Duncan36
posted on 23/4/14 at 07:49 PM Reply With Quote
Illustrator is ace, although Corel may be easy to get to grips with, if it's for occasional use and for drawing basic shapes
www.acorn-printing.co.uk
www.tshirtuk.com
Barlidge
posted on 23/4/14 at 08:00 PM Reply With Quote
Any reason you say that or personal preference? For quick simple bits it works fine for me, anything else I use Illustrator. I learned both Quark and Illustrator many years ago when I worked for a College so the interfaces are familiar.
bi22le
posted on 23/4/14 at 09:56 PM Reply With Quote
If I was making 2D templates I would use draft sight. Its free.
Please read my ring story:
Irony
posted on 24/4/14 at 07:25 AM Reply With Quote
Well there not really comparable bits of software. Quark is a page layout program best suited for magazine/newspaper layouts and illustrator is a vector image editing program. Quark is best compared to Indesign and I would rather use indesign anyway. Adobe is changing the way it sells its software now and you lease the entire creative suite for £450 for a year. This is pretty cheap. Don't see why businesses will pay more money for Quark when they probably already have Indesign. Part of the business I work for is a large printing studio and all the artwork comes through my office. I literally can't remember when I last received artwork in or created by Quark Express - 5 years maybe.......
mcerd1
posted on 24/4/14 at 08:33 AM Reply With Quote
some of the fancy cad packages like Tekla that we use can do wrap-round templates as an option in the parts drawings
(never used that bit myself but I've seen it done)
but most of these CAD packages aren't cheap
Thailoz
posted on 27/4/14 at 11:20 PM Reply With Quote
+ 1 for draftsight its very good I draw what I need and take it to my local laser cutter on a thumbdrive and he cuts them for me.
I print on paper as well
end result from laser cutter (note I re-drilled holes as I made a mistake on my drawings)
Laurence
It may sound a dumb Question to you but to others it may be an eureka moment
Davey D
posted on 28/4/14 at 09:18 AM Reply With Quote
At work we use a program called "Plate n' sheet" for making wrap around templates for pipework. last week we did a fishmouth in a length of 620mm od stainless pipe to butt upto an 800mm radius curve, and the template was spot on
http://www.plate-n-sheet.com/
you can download an evaluation version to try
Smoking Frog
posted on 28/4/14 at 09:46 AM Reply With Quote
I use autocad but free cad software should suit your needs equally well.
New Topic New Reply
