Author: Subject: Ford Focus mk1 fuel level sender wire. Help
D4ENX
posted on 7/2/16 at 10:04 AM Reply With Quote
Hey everyone,
I'm trying to wire in an acewell digital dash and I can't figure out which wire is for the fuel level signal. Both wires I believe went to the standard clocks so currently they aren't attached to anything, does one need power and another is the signal? Does 1 need grounding? I'm seriously stumped by this.
Any help appreciated. Thanks, Dean.
bi22le
posted on 7/2/16 at 10:15 AM Reply With Quote
Looks like a normal mechanical variable resistor to me.
One goes to earth the other is the signal. The dash gives out a reading depending on the resistance it sees to earth.
It looks to me they can go either way round.
DONT PUT 12V POS NEAR IT.
Please read my ring story:
Smoking Frog
posted on 7/2/16 at 11:34 AM Reply With Quote
As above.
You could also measure the resistance across the two connections for full and empty and set the gauge range (if the gauge has selectable ranges) to this.
bi22le
posted on 7/2/16 at 01:22 PM Reply With Quote
Originally posted by Smoking Frog
As above.
You will probably have to do this on the acewell. Part of the set up
D4ENX
posted on 7/2/16 at 01:49 PM Reply With Quote
That's great thanks, seems the problem I had was that I wasn't earthing the other wire. Very knowledgable forum this
