New Topic New Reply
Author: Subject: No Start problem
matt80
posted on 6/10/17 at 06:38 PM Reply With Quote
No Start problem
Evening all. Any suggestions would be greatly received! My red top locost will not start. There is no spark at the plugs. I have changed the plugs, distributor, cap, rotor arm and coil. Is the only thing left the ignition module? It’s driving me mad!!!!!!
posted on 6/10/17 at 07:00 PM Reply With Quote
Do you have a dvm? Then check power and earth continuity to the coil and ignition module. And fuses.
Was it running before
Is battery in good condition to turn engine over quickly
matt80
posted on 6/10/17 at 07:05 PM Reply With Quote
Thank you. I’m very new to all this so unaware about dvm?!
It was running last wed, went to drive it thur and no start! Power getting to and from coil. I’ve taken ignition module off and it’s very worn and dry. I’m told it should have grease on it?
posted on 6/10/17 at 07:09 PM Reply With Quote
Dvm digital volt meter
Cheap and simple models will measures voltage, current and resistance.
Ebay and maplins are good source to buy, b&q and screwfix sell them too.
Re. Ignition module. There are many different ones, can't comment on the information given, a photo may help.
[Edited on 6/10/17 by 02GF74]
907
posted on 6/10/17 at 07:30 PM Reply With Quote
I've always known them as AVO's. Amps, Volts, & Ohms.
posted on 6/10/17 at 07:36 PM Reply With Quote
Yes, and I suppose you still listen to the Queens speech on the wireless and play 78s on your gramophone.
It is 2017 not 1817.
You know I'm joking not having a go, I'm not that much younger.
matt80
posted on 6/10/17 at 07:41 PM Reply With Quote
Hope this helps.
posted on 6/10/17 at 08:05 PM Reply With Quote
Sorry but without details for the specific module it hard to diagnose from a distance.
Generally a base like that is bolted to a heat sink with thermal grease to help transfer heat, the switched electronics inside generate a fair bit of heat, and could be cause of failure.
Assuming it is connected correctly, only way I can see you resolving this is buy substituting a working module.
Make sure it is mounted so as to dissipate heat.
matt80
posted on 6/10/17 at 08:09 PM Reply With Quote
Many thanks for your replies. It was mounted but I took it off ready for a new one. Will keep everything crossed it solves the problem!!
posted on 6/10/17 at 08:21 PM Reply With Quote
You don't say which car/model it may be from but a quick Ebay search seems to indicate it is generic astra /cavalier module, new one for less than £11 e.g 311713056613
New Topic New Reply
