Author: Subject: Zetec crank sensor
AndyPump
posted on 4/10/18 at 05:59 PM Reply With Quote
Zetec crank sensor
Hi all,
I am fitting a zetec 1.6 silvertop to my Locost kit car with ME221 electronic box from Motorsport Electronics.
All is well apart from picking up a crank sensor signal. I have fitted a new crank sensor but still no luck. Does anybody have any ideas if the sensor needs adjustment?
zetec
posted on 4/10/18 at 06:53 PM Reply With Quote
Don't suppose this issue but just in case...the sensor/sensor mounting if different for manual and auto gearbox cars, just in case the engine was original fitted to a car with an auto box.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
furryeggs
posted on 4/10/18 at 07:43 PM Reply With Quote
Have you tried swapping the wires around, i think the ford crank sensors are polarity sensitive.
perksy
posted on 4/10/18 at 08:18 PM Reply With Quote
As Above, Also have you probed for voltage at the sensor?
AndyPump
posted on 5/10/18 at 05:23 AM Reply With Quote
crank sensor
Hi all,
Thanks for replies, I will try reversing the connectors.
I have looked at the flywheel to try and see what triggers the crank sensor but there appears to be no magnets or holes on the flywheel ( I can see the flywheel with the starter motor off.) I am considering an external crank trigger on the crank pulley. Advice welcolm
posted on 5/10/18 at 06:53 AM Reply With Quote
What flywheel are you using?
chris
posted on 6/10/18 at 02:37 PM Reply With Quote
there should be holes in the rear of the flywheel to trigger crank sensor as above what flywheel are you using
[Edited on 6/10/18 by chris]
