Alfa GT stiff clutch.
joneh - 8/4/17 at 08:00 AM
Hi All,
Any suggestions on my mstes Alfa GT JTDM 1.9 - it has a very heavy clutch pedal? Been like it for 3 years, from 30k miles so don't think it needs a new clutch.
Most garages seem to want to fit a new clutch. Forums suggest it seems to be a sticking release bearing or clutch fork getting stuck in bushes.
Thanks!
Jon
rusty nuts - 8/4/17 at 09:44 AM
Is it worth taking the box out to sort the heavy clutch without replacing the clutch? If it was mine I would fit new!
ian locostzx9rc2 - 8/4/17 at 11:21 AM
As said remove gearbox make sure it's all free and replace the clutch
joneh - 8/4/17 at 11:34 AM
Yeah I see your points, looking at the forums some suggest you can grease it without removing the box. Just wondered if anyone had any tips or a similar issue.
perksy - 8/4/17 at 12:38 PM
Is it cable or hydraulic actuation?
joneh - 9/4/17 at 10:51 AM
I'll check with him... I assumed cable.
joneh - 10/4/17 at 08:12 PM
Ok it's hydraulic....
rusty nuts - 11/4/17 at 07:19 AM
If it has an external slave and visible linkage it may be possible to lubricate any visible linkage but if that doesn't work
then it's likely to be box out
