Author: Subject: Piston ring orientation
Monty2556
posted on 3/1/16 at 09:26 PM Reply With Quote
Following on from my last query. The piston rings I'll be fitting will comprise of two compression rings and one complete oil control ring i.e not a control ring consisting of two rings and a separator. What's the correct orientation?
posted on 3/1/16 at 09:33 PM Reply With Quote
Read the information sheet that came with the Pistons, if you haven't got one ask your piston suppliers.
Failing that look at the packaging for the rings.
tr7v8
posted on 3/1/16 at 10:25 PM Reply With Quote
The rings are normally marked top as they'll be keystone shaped or tapered.
Ring gaps will be as far apart as possible so 120 degrees from each other.
Unless you're experienced then get a ring expander, otherwise you WILL break them.
Also use a stone to put a very slight radius on the outer edge or the ring gap to stop it digging in.
Jim
2005 Porsche Cayenne S
2000 Jeep Grand Cherokee Sold
2010 Maxda MX5 Sport Tech
2000 Porsche Boxster S (now sold)
Light travels faster than sound. That's why certain people appear bright until you hear them speak.
mark chandler
posted on 3/1/16 at 11:14 PM Reply With Quote
Piston rings rotate on the piston when running, around 75rpm at normal engine speeds from memory, just make sure you get the correct ones in ten correct place and the right way up!
britishtrident
posted on 4/1/16 at 11:06 AM Reply With Quote
If you need a ring expander I have one that I am unlikely to ever need again.
[/I]
