Author: Subject: Zetec flywheel compatibility
PJCTHolmes
posted on 13/2/16 at 08:35 PM Reply With Quote
Hi collective, hoping that someone could offer some knowledge on my upcoming engine swap!
I currently have a 1.8 silvertop and am swapping to a
2.0 silvertop. I have a lightened flywheel on the 1.8 that I
Want to transfer over. Would the bolt patterns be the same?
Anything else to watch out for?
Ugg10
posted on 13/2/16 at 09:13 PM Reply With Quote
As far as I am aware it will fit, quick way of enhancing the 2.0l silvertop is to put on a stock 1.8 flywheel which is 2kg lighter.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
PJCTHolmes
posted on 13/2/16 at 09:18 PM Reply With Quote
Here's hoping for a straightforward job then! Thanks
19sac65
posted on 14/2/16 at 10:05 AM Reply With Quote
If you want to save another couple of kg try and get a late cvh efi FW with the crank sensor marks on the back
Just drill the 10mm holes to 11mm and it bolts straight on
Has the same clutch bolt patterns so you can use a 16/1800 mondeo cover and plate
posted on 14/2/16 at 02:38 PM Reply With Quote
The bolt pattern is the same for mall zetecs because the crank is the same for every size engine right up to the last one for the focus rs mk1.
PJCTHolmes
posted on 14/2/16 at 05:16 PM Reply With Quote
Excellent, cheers guys!
