Author: Subject: Rover / TVR V8 enigne dimensions / drawing
grazzledazzle
posted on 11/12/08 at 09:42 PM Reply With Quote
Does anyone have a drawing of the RV8 engine or dimensions for it? Colleague thinking about a new project and we wondering if the TVR RV8 with t5 box would go in.
Thanks.
AdamR
posted on 11/12/08 at 10:22 PM Reply With Quote
I may just be able to help! Note that the TVR RV8/T5 combo uses a different bellhousing to mine and probably has the alternator a bit lower down.
V8 + T5 dimensions
V8 + T5 dimensions
AdamR
posted on 11/12/08 at 10:28 PM Reply With Quote
A couple of other things....
Dimensions are a bit screwed - assume accuracy +/- 3mm, and the TVR T5 has the shifter further forward (my box is from a Sierra Cosworth).
[Edited on 11/12/08 by AdamR]
grazzledazzle
posted on 12/12/08 at 10:38 AM Reply With Quote
Top man. Bloody brilliant!
Does the cosworth T5 bolt onto the engine? I've got one of those in the garage...
AdamR
posted on 12/12/08 at 11:35 AM Reply With Quote
Yep, no probs with the Sierra box or TVR box... they're the same as far as I know, apart from gear lever pos and ratios.
