Author: Subject: Engine assembly lube
scutter
posted on 22/7/02 at 11:01 AM Reply With Quote
Anyone know which is the best assembly fluid?(que jokes), as engine maybe standing for quite some time before start up.
UncleFista
posted on 22/7/02 at 11:40 AM Reply With Quote
I've used STP oil treatment in the past, looks like oil but thicker. Never had any problems with it, sticks like glue to plain metal surfaces...
Tony Bond / UncleFista
scutter
posted on 22/7/02 at 09:37 PM Reply With Quote
Cheers unc, at least it one thing that i recognise in the local motorfactors. Scutter.
marcjagman
posted on 2/8/02 at 08:56 AM Reply With Quote
Or you could use something similar to Slick 50 called PTFE 4 oil made by a company called Add-it from Doncaster, as good as Slick 50 but less than half the price that way it is protected while standing and running.
UncleFista
posted on 2/8/02 at 11:11 AM Reply With Quote
As good as slick 50 ?
So crap then ?
PTFE is a solid, not designed to be mixed with oil and used to lubricate an engine.
Slick50 = snake oil
IMHO of course
posted on 2/8/02 at 12:05 PM Reply With Quote
Anyone using these additives might like to look at this site...
http://www.fernblatt.com/longhurst/additives.html
johnston
posted on 2/8/02 at 05:12 PM Reply With Quote
was told once by an engine builder to use somethin but cant remember for sure but i think it was two strke oil i no the marine stuff can be pretty thick and a real pig to get off 2 so it might be that????
any1 heard similar
