Author: Subject: 3.62 sierra diff ??
dean7499a
posted on 15/3/09 at 09:00 AM Reply With Quote
3.62 sierra diff ??
hi can anyone tell me which model sierra used a 3.62 diff ? cheers.
posted on 15/3/09 at 09:04 AM Reply With Quote
check out the info at the top of the engine and transmission forum.
dean7499a
posted on 15/3/09 at 09:06 AM Reply With Quote
i have got the codes but just thought it would be easier to know which model for when going to scrapyard
wilkingj
posted on 15/3/09 at 09:09 AM Reply With Quote
Usually the 4x4 models have the LSD. But you will need to check the numbers on the Diff.
The ratio is stamped on the tag like 362 for a 3.62
Cant say about the LSD bit.
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 15/3/09 at 09:10 AM Reply With Quote
you cant really be 100% sure from the models as nothing was set in stone it seems. Best bet is to check the vin plate under the bonnet as ive never seen one where the code was wrong. U for 3.62 in the box 'axle pt ar'.
jacko
my dohc 2l G reg had one 3.62
t16turbotone
posted on 15/3/09 at 09:31 AM Reply With Quote
yes.....2ltr dohc model has 3.62 however it was a 7.5 inch
mistergrumpy
posted on 15/3/09 at 09:46 AM Reply With Quote
I'm on my 3rd diff and looking for a 4th I think for various reasons but whenever I've looked around the scrap yards it just seems to be a lucky dip and it's quite hard to identify what the models are if they've lost their boot or the badge on them.
I just stick with the VIN plate code, it's a bit like Christmas. Struggle to open the bonnet wrapping then get a surprise when you read the code!
NS Dev
posted on 15/3/09 at 02:09 PM Reply With Quote
No it didn't!
It may have some obscure measurement across the mounts but it has a 7" crownwheel, which is what the measurement on sierra diffs refers to.
In answer to the question, all the hatchback v6 XR4x4's that I have EVER seen were fitted with 7" 3.62:1 ratio LSD's as std.
My Ford bible also states that these were only ever fitted with this ratio and diff size.
The 2.0 dohc 4x4's had 3.92:1 7" LSD's
t16turbotone
posted on 15/3/09 at 04:13 PM Reply With Quote
And ime telling you it did ...ok
jacko
posted on 15/3/09 at 04:23 PM Reply With Quote
NO mine is a 7in diff thats what fit the MK indy and i removed mine from a 2l g reg dohc
Jacko
[Edited on 15/3/09 by jacko]
t16turbotone
posted on 15/3/09 at 05:05 PM Reply With Quote
good for you.....mine was a 7.5"
jacko
posted on 15/3/09 at 07:35 PM Reply With Quote
It looks like were both right
no4
no4
The 2L Dohc car had 7.5 diffs and 7ins diffs
More info in my photo archives
Jacko
t16turbotone
posted on 16/3/09 at 06:42 AM Reply With Quote
Thankyou jacko, nice to know ime not going mad
NS Dev
posted on 16/3/09 at 01:05 PM Reply With Quote
Ok, I now feel re-educated!
You've got to ask why ford did that!!!
Guess they made too many 7.5" carriers and wanted to use em up!
bob
posted on 16/3/09 at 01:09 PM Reply With Quote
NS Dev
posted on 16/3/09 at 01:20 PM Reply With Quote
that's what i have, btu it doesn't include the one fly in the ointment "discussed" above!
Looks like some DOHC 2.0 models got the 7.5" diffs.....
The only car above with 7.5" that was sold in the UK would have been the XR4i, as that's the only factory 2wd v6 sierra that was made.
bob
posted on 16/3/09 at 01:27 PM Reply With Quote
I just realised that attatchment i put up is dated 1987, so i'm thinking the DOHC models like the 2.0GLSi wouldnt be listed.
I do get a feeling though that in the last couple of years of sierra production nothing is as the norm.
