Author: Subject: Clutch bleeding:(
Simon
posted on 27/2/04 at 11:28 AM Reply With Quote
Clutch bleeding:(
Right. I bled clutch. Bled it again. Bled it again.
It works for the last inch of travel.
Standard Rover SD1 slave, Wilwood 0.7" master (standard 0.625"
I'm sure I put clutch plate in right way round!
Any tips for bleeding please.
Simon
timf
posted on 27/2/04 at 11:42 AM Reply With Quote
ez-bleed kit
jonti
Silly question maybe but, does the actuator arm move immediately you start to depress the pedal ?
If not and there's no slack between the slave punger and the arm then..hydraulic probably
If it does then it's mechanical internal to the clutch.
OFROK
Simon
posted on 27/2/04 at 05:13 PM Reply With Quote
Tim,
Bought a new ezbleed just for the job, and magaged to get 1/2 pint of brake fluid inside my car (with 4psi tyre!) poxxy thing didn't seal properly to master cyl
Will have another go at bleeding over weekend and (as I haven't got the sh*t plate) I'll see if I can see what it's doing inside!
Simon
jonti
posted on 27/2/04 at 11:31 PM Reply With Quote
Dont mention it cock.....glad to be of help.
OFROK
