Author: Subject: Under bonnet temps 1300 x flow
myke pocock
posted on 14/6/09 at 09:16 AM Reply With Quote
I have a standard 1300 x flow with 4, 2, 1 Escort Sport (I think) exhaust manifold. I have lagged the system with one layer of exhaust tape to where it exits the side panel but the under bonnet temps still appear high. Not on the road yet but has anyone with this set up put any vents in the bonnet? If so, pics would be interesting, or a link.
omega0684
posted on 14/6/09 at 09:25 AM Reply With Quote
if you haven't got flared side panels then i would definately put some sort of ventilation at the back of the bonnet
DavidM
posted on 14/6/09 at 09:34 AM Reply With Quote
I made vent for the side panel next to the manifold. I've no other holes or vents in the engine compartment and underbonnet temperatures have not been an issue.
[img] Scuttle 2008
Scuttle 2008
[/img]
[img] Vent 2008
Vent 2008
[/img]
[Edited on 14/6/09 by DavidM]
Proportion is Everything
posted on 14/6/09 at 01:03 PM Reply With Quote
smae engine and manifold as you.
the bonnet above the manifold would get to how that I could not hold my hand on the bonnet.
So I did two things. fitted B&Q aluminium ventilator louvres to let heat out and above the exhaust, a second aluminium plate to act as heat shield.
sit tight and I'll pop off downstairs for somoe photos.....
posted on 14/6/09 at 01:08 PM Reply With Quote
here we go. (view from underside).
notice the aluminiujm angle stiffeners to make bonnet a bit less floppy. Rescued attachment DSC04709.JPG
wicket
posted on 15/6/09 at 11:25 AM Reply With Quote
My 1600 x-flow got very hot and the bonnet was to hot to touch. However, these vents seem to have made a dramatic improvement. Not actually measured the temperature but the surface of the bonnet is significantly cooler than before. The vents are now painted black and look much nicer in my opinion.
