Author: Subject: Under car exhaust system.
Sebastian
posted on 20/8/09 at 08:40 PM Reply With Quote
Who has some pictures of an exhaust system of a Seven that is running underneath the car.
I m looking at getting my exhaust out on the back, i currently run my exhaust standard on the side so i would like to see i how you guys did the extension to the back and where to place the silencer.
Thanks in advance.
NeilP
posted on 20/8/09 at 08:48 PM Reply With Quote
I think that Johnmor has done his underneath (he's got a Viento running an Alfa V6 IIRC so it's a twin pipe jobby to boot...
EDIT: Yep...
Back box
Back box
Center box
Center box
[Edited on 20/8/2009 by NeilP]
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
Steve Hignett
posted on 20/8/09 at 08:51 PM Reply With Quote
omega0684
I dont think there are any on this forum, i know that bob (V8YOB) on the DAX Sporting Club forum has under car exhausts but i don't see any benefits, only disadvantages, 1) a very hot bum, 2) where you going to put the silencer(s), 3) you have to route it around the suspension if running de-dion set up 4) you have the heat shield the fuel tank A LOT!
WHY? What's wrong with the set up you have now?
jpindy3
posted on 20/8/09 at 09:05 PM Reply With Quote
not my cup of tea,but steves looks sweet.
balidey
Several years ago Nigel Dean did it on his westy seight.
LBMEFM
posted on 20/8/09 at 09:07 PM Reply With Quote
Surely ground clearance must also be very tight, especially over speed bumps etc.
blakep82
posted on 20/8/09 at 09:17 PM Reply With Quote
will is going down the tunnel. not much good to you if yours is already built though, as you'll need a wider tunnel i think
________________________
Steve Hignett
posted on 20/8/09 at 09:19 PM Reply With Quote
Ahem - "steve's" is actually BigRich's!
I've posted the photo on his behalf so many times, I just don't bother giving him credit for them anymore!
m8kwr
posted on 21/8/09 at 06:28 AM Reply With Quote
Steve - the exhaust cans in the picture you put up, what are they???
many thanks
sebastiaan
posted on 21/8/09 at 08:33 AM Reply With Quote
Have a look at a Donkervoort (D8). They've got the exhaust coming out the side, then a (huuuuge!) silencer in the "normal" location and then feed a pipe through the rear wing, over the suspension and down again (following the rear wing profile; these cars have wide rear wings, so there is plenty of space inside the wing without having clearance issues around the tires). The exhaust then exits at the back. Lots and lots if heat shielding involved, but a nice solution.
Good luck!
Sebastiaan (double A, but also LHD in holland ;-))
Steve Hignett
posted on 21/8/09 at 09:21 PM Reply With Quote
From memory, I think they are 2006 R1 Cans that Rich stole from his brother...
Well I think he bought them, but that doesn't sound as good as if he stole them from a close family member
Send Bigrich a U2U and he'll tell you all about them and the way he fitted 'em too
many thanks
