Author: Subject: inlet manifold construction
cd.thomson
posted on 22/9/09 at 05:28 PM Reply With Quote
Hi guys, I feel embarrassed posting another of these threads after people have been so helpful in the past already..
My garden shed fabricator has backed out of making my inlet manifold as it is "too complicated", I still have the flange so I was thinking of going to a proper fabrication company in Burton/Derby but for that I will need to take plans. Better still, as recommended by blake, I could prepare the tubing myself and get them to weld it together.
The first hurdle arises because the ports on the XE flange are oval and the carbs I've just bought are round. What fabrication wizardry will have to be performed to get a pipe with one round end and an oval end?
I'm hoping to do something similar to this:
[Edited on 22/9/09 by cd.thomson]
Craig
cd.thomson
posted on 22/9/09 at 05:39 PM Reply With Quote
also, just to add, I know theres a few people on here involved in various kit car related fabrication jobs. If you think you can produce something then or know someone who can I'd happily employ you to do it .
Craig
adrianreeve
posted on 22/9/09 at 05:40 PM Reply With Quote
Put the tube in a vice and gently squeeze! Do it a little at a time, and the tube goes a lovely oval shape. I did it this way with mine and they came out brilliantly.
Here's a link to another thread: Not the best pics but hopefully you get the idea.
http://www.haynes.co.uk/forums/showthread.php?t=1843
HTH
Adrian
[Edited on 22/9/09 by adrianreeve]
flak monkey
posted on 22/9/09 at 06:00 PM Reply With Quote
Yep, gently squeeze in a vice. Simple as that.
Then, once you have it somewhere close, tack it onto the plate and then use a punch to knock the tube into its final shape.
Its possible to make some complex shapes with some practice.
Inlet manifold 4
Inlet manifold 4
Sera
http://www.motosera.com
cd.thomson
posted on 22/9/09 at 06:06 PM Reply With Quote
cheers adrian and david,
i cant see those pictures unfortunately, the problem i imagine happening is that the oval will be larger than the port itself despite being the same shape. This will create a substantial lip at the inlet end of the manifold which will catch fuel and all sorts (i think?).
tell me if im visualising it all wrong!
Craig
adrianreeve
posted on 22/9/09 at 06:20 PM Reply With Quote
It obviously depends on the application, but for the zetec engine, 45mm tube was perfect for the round end at the throttle bodies, and when squeezed, matched the oval port shape exactly (and it really was exactly!)
Adrian
omega0684
posted on 22/9/09 at 06:34 PM Reply With Quote
those pipes look rather loooooooong
cd.thomson
posted on 22/9/09 at 06:48 PM Reply With Quote
6 inch total runner length to keep the max torque down at a sensible level I think
Craig
andrew-theasby
posted on 22/9/09 at 07:10 PM Reply With Quote
ive just made one this week for my xe. I used 48mm x 4mm wall tube to suit t/b's. I cut 4x 30mm long pieces then turned a v into then for the mounting rubbers. then using a hole saw, cut 4 48mm holes in a piece of wood on same centres as t/b's. I mounted this to another piece of wood at the right angle and distance i wantedd from the head. The flange was then clamped on to this centrally and the 4 short tubes put in pkace flush with the top. Then i cut 4 more lengths of tube to filt the gap. trial and error proved i had to cut a v in these first then weld them back up so ene endnd was smaller dia. then i squashed them to an oval and mitred them as necessary with slitter and a lot of grinding, then tacked it aall up then fully welded it. Took it out of the jig, shot blasted it, smoothed the inside with liquid metal and painted it. Its a lot of work, and if you dont feel upto it, id definitely try bogg broos for a price first otherwise youll waste a lot of time and still end up buying one. HTH, ill poost up soome pics when i get home on saturday ifyou like.
will121
posted on 22/9/09 at 07:40 PM Reply With Quote
have a look at this basic guide ive done for zetec manifold fabrication, principal is the same. it does make the manifold easier to make if you re-space the carbs but not essential. easiest way i found to make bends is to cut a wedge out rather than cut off totally.
guide to making a manifold
cd.thomson
posted on 22/9/09 at 07:42 PM Reply With Quote
id love some pictures Andrew. I was quoted close to £400 for carbs and a manifold from bogg yesterday which is eye watering for a second hand part fitted to some metal tubing.
Craig
andrew-theasby
posted on 22/9/09 at 09:14 PM Reply With Quote
Didnt realise theycharged thatmuch, was expecting morelikee 150 for a manifold. U2U me ifi dont post them up on saturday. Ps sorry bout th ttyping my keyboards playing up andn cant be bothred to edit eeverything
andrew-theasby
posted on 25/9/09 at 11:27 PM Reply With Quote
andrew-theasby
andrew-theasby
posted on 25/9/09 at 11:28 PM Reply With Quote
mr T
posted on 26/9/09 at 01:37 PM Reply With Quote
Bog Bros
Got mine from Bogs worth the money
