Author: Subject: Balancing Bike carbs using slide type balancer?
FASTdan
posted on 28/11/09 at 05:10 PM Reply With Quote
We've just fitted ZX9R carbs to our pinto, but we have the balancer with the 4 pipes + slides. Looking around I cant see any taps into the carbs where these could be fitted. And also looking on ZX forums I've seen diagrams indicating that the balancer would need connecting to the head.
Has anyone successfully used one of these balancers on bike carbs? I know you can get the alternative 'plug in' type balancer that bungs the trumpet - could you perhaps adapt our type of balancer to do this job?
jacko
posted on 28/11/09 at 05:16 PM Reply With Quote
I had to put a vacuum pipe on each manifold runner for a balances
or you can use a balance gauge that fits where the air filter goes on the carb mouth
Jacko
painted manifold
painted manifold
The 4 bolts are were the vacuum pipes fit
[Edited on 28/11/09 by jacko]
RAYLEE29
posted on 28/11/09 at 05:44 PM Reply With Quote
Hi, you need to drill and tap 5mm holes in the manfold runners to use proper gauges to balance the carbs so you can prob do the same with your slide things
Ray
whitestu
posted on 28/11/09 at 08:08 PM Reply With Quote
On most bikes the connection for the balancer is on the rubber inlets, not the carbs.
It is common enough to use needles to pierce the rubber on bikes that don't have take offs in order to tap in to get a vacuum reading [morgantune kits come with these], but I wouldn't do it personally.
Stu
FASTdan
posted on 28/11/09 at 09:17 PM Reply With Quote
Stu
Not a bad idea I suppose - if you were to have a spare set of rubbers for balancing only?
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
whitestu
posted on 29/11/09 at 09:43 AM Reply With Quote
Seems like a good idea to me.
I think I've got some of the needles you can borrow if you want to have a go.
Stu
FASTdan
posted on 30/11/09 at 01:16 PM Reply With Quote
Stu
Thanks for the offer mate will keep it in mind, as im not sure if we'll bother setting them up on the pinto as this was only really a test before we use them on our duratec. Once thats in though we will need to balance them.
