Author: Subject: GEARBOX STEEL INPUT HOUSING - WANTED
Furry
posted on 4/2/10 at 09:16 PM Reply With Quote
Hello everyone,
following my post about a rattling clutch, i decided to bite the bullet and remove the engine to sort it. unfortunately when i did i found that the above part was snapped off and sat on the input shaft. i was wondering if anyone had one spare.
i believe they were fitted to the following gearboxes
TYPE3
• Cortina Mk2
• Cortina Mk3 1.3/1.6/1.6GT
• Cortina Mk4/5 1.3, 1.6 (not GT)
• Lotus Cortina 69-
• Capri Mk1/2/3 1.6 OHC
• Capri Mk1 -8/72 1.6 OHV
• Capri Mk1 2.0 V4
• Sierra 1.6
2000E 'Bullet' Gearbox
• Cortina Mk1
• Lotus Cortina Mk1/2 -68
• Escort RS1600/Mexico
• Escort Twin Cam
please see picture in archive of the part i need
[Edited on 4/2/10 by Furry]
jacko
posted on 4/2/10 at 09:22 PM Reply With Quote
STEEL INPUT HOUSING, LATE TYPE, 2000E & TYPE 3 GEARBOX
RAYLEE29
posted on 4/2/10 at 10:51 PM Reply With Quote
Hi, a few years back the courier delivering my cossie t5 box dropped it off the van staight onto the first motion shaft snapping the housing anyway as a new one wasnt available i cleaned it up and ran a nice bead of braze around it.
its only there to keep the thrust bearing central so its not loaded at all so if you can braze or know someone that can its a cheap and easy fix
Ray
[Edited on 4/2/10 by RAYLEE29]
blakep82
posted on 5/2/10 at 10:13 AM Reply With Quote
i've got one off a type 9. don't know if they're the same
i'm also away now til sunday nite/monday morning
________________________
posted on 5/2/10 at 10:38 AM Reply With Quote
Something else must be wrong -- I would advise you get another gearbox and check a spigot bearing is fitted in the end of the crankshaft.
