Author: Subject: Header tank plumbing - choose one!
posted on 13/4/10 at 07:58 PM Reply With Quote
I have at least 3 ways of plumbing the raditor bleed to the header tank, as shown in following (wait until I have posted all 3 options!!)
option 1 - route pipe along radiator then over the spark plugs, trying to keep pipe away from the exhaust. Rescued attachment version1.jpg
posted on 13/4/10 at 08:01 PM Reply With Quote
option 2 - take hose diagonally over te rocker cover - uses 1 less joiner plus and shortest hose Rescued attachment version2.jpg
posted on 13/4/10 at 08:02 PM Reply With Quote
option 3 - takes hose over the carbs.
I kinda like 1 and 3 due to nice lines nad probably 3 since the hose will be supported by the carbs; I cannot forsee the hose being so close to the carbs posing any problem.
55ant
posted on 13/4/10 at 08:04 PM Reply With Quote
i have the same layout as n.1, not had any problems with heat from the exhasut.
Confused but excited.
posted on 13/4/10 at 08:05 PM Reply With Quote
I personally think 3 looks the more elegant solution.
No 1 would look better if you had a straight piece of ali tube where it goes across the exhaust.
[Edited on 13/4/10 by Confused but excited.]
blakep82
posted on 13/4/10 at 08:06 PM Reply With Quote
i would probably just go number 2. as long as the middle of the pipe is not the highest bit
________________________
jacko
posted on 13/4/10 at 08:07 PM Reply With Quote
No 3 looks good
speedyxjs
posted on 13/4/10 at 08:08 PM Reply With Quote
I think number 3 looks best.
posted on 13/4/10 at 08:10 PM Reply With Quote
ooooh, level peggings at the mo.
The joiners will be 10 mm aluminiium tube from B&Q - just need to figure out how to put flares on (thinking a couple wraps of aluminum MIG wire then lumiwelded on).
The aluminium will pass the heat from the exhaust - it gets rather hot in that area to the water - not sure I like the sound of that.
40inches
posted on 13/4/10 at 08:11 PM Reply With Quote
No3 for me
blakep82
posted on 13/4/10 at 08:12 PM Reply With Quote
number 3 looks to me like its just resting on the carb/filters and brake resevior, which i don't like tbh.
if you want to avoid the exhaust, what about, like option 1, but fixing it down the carb side of the rocker cover?
40inches
posted on 13/4/10 at 08:14 PM Reply With Quote
A pair of Oyster pliers from B@Q.
Check this thread
[Edited on 13-4-10 by 40inches]
balidey
posted on 13/4/10 at 08:20 PM Reply With Quote
No 3
Dutch bears have terrible skin due to their clogged paws
RichardK
posted on 13/4/10 at 08:29 PM Reply With Quote
3
Gallery updated 11/01/2011
SPYDER
Another vote for #3.
Just as an aside. Every bit of water that flows through the breather tube will bypass the radiator matrix and not get cooled. This could amount to a fair bit given the bore of the tube you are using.
Consider some form of flow restrictor in the breather tube, maybe?
I'm not 10% au fait with crossflows though, I may be over-reacting.
When the thermostat is closed, is there any flow at all through the system?
Geoff.
posted on 13/4/10 at 08:32 PM Reply With Quote
may look like it but deffo not resting on the reservoir.
no matter how I plumb it, it will be resting on the engine so there will be some movement or a long unsupported run - not sure if that is pissible unless I use an aluminiuim tube.
posted on 13/4/10 at 08:35 PM Reply With Quote
yes - there is a take off from the water pump - you can see it below the "breather" tube that then goes to the manifold and there is a T that goes to bottom of header tank.
there is potential for coolant to go from the T piece into the tank but the iar in the tank should prevent it leaving the tank and going into the radiator breather.
blakep82
posted on 13/4/10 at 08:57 PM Reply With Quote
if you run it down the carb side of the rocker cover, you can use the two rocket cover bolts with P-clips to secure it
tul214
posted on 13/4/10 at 09:04 PM Reply With Quote
What about moving the header tank to the front like Caterham do?
1.6 Raw Super6 sold
speedyxjs
posted on 14/4/10 at 06:14 AM Reply With Quote
Check this thread
X2. There is also a cool vid on youtube of mango demonstrating it
posted on 14/4/10 at 06:36 AM Reply With Quote
1/2 wondered about that but the min mark on the header must be above the highest part of the cooling system which is the radiator and here is not enough rooom under the bonnet or nosecone to have it too far forawards.
I wouldn't like to mount it above the exhuast nor alternator so only spot is close to the coil and I don't think I have the room heightwise there.
Will have a look tonighty.
posted on 14/4/10 at 08:37 AM Reply With Quote
I'm going to stick my neck out and go with no. 2, but with a slight mod.
Run the hose down the intake side of the rocker cover (not over the top) and fabricate some ally brackets and rubber lined P clips to support the pipe of the rocker cover or inlet fixings.
Keeps the hose away from the carbs and exhaust and if done carefully could look like an OEM type installation
