Author: Subject: Loads of crossflow bits fs - 11 miles from Stoneleigh
Dave Ashurst
posted on 1/5/10 at 04:25 AM Reply With Quote
If anyone wants any crossflow engine parts I can probably help (all these are used unless stated otherwise):
camshafts (inc one billet steel Piper 285)
new cam followers (made in germany - i.e. not the recently problematic mocal parts from india supplied by Kent and Piper)
cyl heads (various standard and big valves inc one with offset monster valves) (ONE BIG VALVE HEAD RESERVED FOR MIKE)
blocks (well, at least one - that from a 1700 hillclimb mallock and needing a rebore - worth a go perhaps)
1600 sump - I think I've got one at least. (SOLD)
cast pistons (standard and +90thou) (ONE SET OF +90 PISTONS RESERVED FOR MIKE)
rods (cast 1600) (AT LEAST ONE SET RESERVED FOR DAVID)
1600 cranks (at least 2) (AT LEAST ONE RESERVED FOR DAVID)
timing chains (duplex/simplex) (Edit; Including gears.)
chain covers (at least 2) (ONE RESERVED FOR MIKE)
crank seal covers (ditto)
push rods (1600)
oil pick ups
rocker covers (at least 1 I think)
flywheels (standard and lightened, including a nice light steel one) (AT LEAST ONE RESERVED FOR DAVID)
Clutches (used but serviceable, including a twin plate race clutch for the steel flywheel - needs new plates)
oil pumps (high pressure and standard - a bucket full)
fuel pumps (mechanical ones off engines I've cannibalised)
Original downdraught weber carbs and manifolds.
ford 4 speed gearboxes; a selection of type 3 and type 2
A broken, plate-type, English axle LSD, (end cover shattered but all else looks intact) as a bucket of bits - recoverable? I dunno. (RESERVED FOR PAUL)
various clutch arms
alternators
Starter motors
one pair of new K&N filters, DCOE40 fitting, boxed, unused (except for a 15min test drive!). (type ref 56-9105 54mm high)
plus other things I don't know about ...
Any questions drop me a line by U2U or if anything takes your fancy make me an offer.
To be honest I'm not sure what else I've got in storage, but I'm near Stoneleigh and I'm having a clear out. It will all go on ebay later in the year.
best
D
[Edited on 2/5/10 by Dave Ashurst]
Dave Ashurst
posted on 1/5/10 at 12:24 PM Reply With Quote
Paul
Photos of the LSD are in my archive.
best
Dave
MikeR
posted on 1/5/10 at 12:52 PM Reply With Quote
dave, interested in the big value head and front timing chain cover and 90thou pistons depending on price and condition. Away at mo, will contact when back if bits still available.
Dave Ashurst
posted on 1/5/10 at 01:05 PM Reply With Quote
Mike,
No probs, they're still in the storage unit so far Give me a call when you're ready then come and have a browse.
I've also got some new unused boxed 90thou 1300 pistons which will give high compression on a 1700 depending on valve cutouts needed.
Dave
irvined
posted on 1/5/10 at 01:44 PM Reply With Quote
Hi David,
I'm interested in the Sump, cranks, rods, flywheels and some other bits, I'll likely be over next weekend if you're around.
http://irvined.blogspot.com
shaun megablade
posted on 1/5/10 at 05:41 PM Reply With Quote
you have u2u
Dave Ashurst
posted on 1/5/10 at 08:06 PM Reply With Quote
Originally posted by irvined
Hi David,
Sump's gone, sorry. Lots of other bits though. I'll be home next weekend, see you then?
In Utrecht in the week though, are you up for a beer Monday or Tuesday night?
D
Dave Ashurst
posted on 1/5/10 at 08:12 PM Reply With Quote
Originally posted by shaun megablade
you have u2u
Shaun
so do you
and sorry, you're second in line.
best
D
Dave Ashurst
posted on 2/5/10 at 04:56 PM Reply With Quote
Ewan,
There's a photo of the K&N filters in my archive.
best
Dave
Seven_Monkey
posted on 4/5/10 at 12:49 PM Reply With Quote
Hi Dave, I wonder if you have any standard 1300 pistons (am I right in saying these go straight into a 1600 without mod to give higher comp?).
Let me know if you do - currently rebuilding a 1600 so could be interested in other ancillaries etc...
Rich
Build Thread - http://www.locostbuilders.co.uk/viewthread.php?tid=134121
Dave Ashurst
posted on 4/5/10 at 10:53 PM Reply With Quote
Rich
Hi Rich,
Sorry I don't think I've got any standard size 1300 pistons.
D
Dave Ashurst
posted on 7/5/10 at 06:52 AM Reply With Quote
LSD sold.
Furry
posted on 15/5/10 at 10:31 AM Reply With Quote
hi dave, i'm currently looking for a input housing for my 2000e gearbox, apparently it's the same as the type 3 one, see picture. would you be interested in selling me one and posting it as i'm fed up of not having my toy. many thanks
Dave Ashurst
posted on 15/5/10 at 09:52 PM Reply With Quote
Hi Paul
Sorry mate. I don't have a spare.
The only one I've got is intimately attached to a nice, 4 speed, type 3 gearbox.*
[EDIT: *It came as part of a engine and gearbox set out of a hillclimb mallock that was being upgraded. According to the architect I bought it from, the gearbox was professionally rebuilt each season.
I only really wanted the engine but he wouldn't split. So here we are.
It comes complete with bellhousing
D ]
regards
Dave
[Edited on 16/5/10 by Dave Ashurst]
Dave Ashurst
posted on 16/5/10 at 12:10 PM Reply With Quote
ShaunB,
the K&N's are yours.
See U2U on postage options.
best
Dave
Dave Ashurst
posted on 21/5/10 at 10:12 AM Reply With Quote
Oops, must have been asleep when I posted that last one.
I meant :
Shaun - The PISTONS (not the K&N's) are yours and they're on their way. See U2U.
Ewan - the K&N's are YOURS, they are packed and ready to go - but I urgently need your address!! Also see U2U.
best
D
sionjames
posted on 9/5/11 at 01:06 PM Reply With Quote
piper 285 cam
hello there
i no its bit l8 but would you hapen to have the piper cam?
if so is it new and how much?
thanks sion
Dave Ashurst
posted on 10/5/11 at 06:18 PM Reply With Quote
Hi Sion,
Sorry, it's gone
No it wasn't new.
good luck
D
bmseven
posted on 15/5/11 at 08:00 AM Reply With Quote
Old advert I know but worth a try .......Rocker cover?
best
D
BMW 7 Resource
Bures Pit anyone?
basford
posted on 15/5/11 at 09:28 AM Reply With Quote
Timing Chain.
How much for the timing Chain and Gears.?
posted on 15/5/11 at 11:39 AM Reply With Quote
best
D
If Dave can't help I have a pressed steel type
Dave Ashurst
posted on 15/5/11 at 09:48 PM Reply With Quote
Guys,
Sorry, I can't check my storage unit until the weekend. So, I think I've got:
A rocker cover or two, pressed steel type.
Duplex timing gears and chain £20
Simplex ditto £10
Choice of duplex depends on the depth of your timing chain cover. (I have deep timing chain cover suitable for duplex set.) Both chain sets are used, both are offset dowel fitting, not vernier type.
You can probably see some of these in my photo archive, but I haven't updated it for a while and several things have gone.
EDIT to add: I just looked at the photos. They were a random and incomplete set. We didn't photograph everything.
Feel free to U2U me your questions and I'll do my best.
best
D
[Edited on 15/5/11 by Dave Ashurst]
bmseven
posted on 17/5/11 at 07:02 AM Reply With Quote
no worries was looking for an ally one.
BMW 7 Resource
Bures Pit anyone?
