rich201283
posted on 27/5/04 at 10:27 AM |
Can you use flexi exhaust pipe from the manifold to the exhaust pipe ?
Can you use flexi exhaust pipe from the manifold to the exhaust pipe because my steering rod fouls the path of the exhause and it will be very tricky
to make a downpipe up.
posted on 27/5/04 at 12:43 PM |
it will be very tricky to make a downpipe up
It'll be going the wrong way if it's a downpipe and you make it up. I think Mark Allanson used some in his front section,
try a search.
Mark Allanson
posted on 27/5/04 at 06:10 PM |
Got my flexible bits from the local factors, only £9.00 each
stephen_gusterson
posted on 27/5/04 at 07:11 PM |
Mark
do they weld on? or clamp on?
I have some nasty convoluted crappy stuff running from my downpipes to exhaust proper - yours looks better.
do they come longer? and how flexy (hard to describe I know) are they?
atb
steve
Mark Allanson
posted on 27/5/04 at 07:21 PM |
They come in various diameters and lengths, I welded (now there is a surprise!!), but your could clamp them just as easily
posted on 27/5/04 at 09:05 PM |
if my beastie fails its noise test i'll be needing some of this stuff, to extend the exhaust away from the engine and add an extra silencer.
stephen_gusterson
posted on 27/5/04 at 10:20 PM |
thx mark
posted on 27/5/04 at 11:28 PM |
Cheers Steve.
. I used one of these to repair a Merc van exhaust, cut and shut weld job. They are available in various diameters but there is still a convoluted
tube inside the mesh.
[Edited on 27/5/04 by Peteff]
