Author: Subject: what diff is it?!?
typ17
posted on 18/9/10 at 05:00 PM Reply With Quote
what diff is it?!?
Just took a diff out of a 93 sierra with a 2.0 engine.
The serial on it is 85GG 4025 CB and I can't find any reference to this number...
Not even sure if it is a 7" or a 7,5"...
It has bolt on shafts and rear solid disks.
Any clues on what it might be?
Thanks for the help.
spiderman01980
posted on 18/9/10 at 05:06 PM Reply With Quote
linky
jacko
posted on 18/9/10 at 05:07 PM Reply With Quote
The one on the right is a 7.5 diff
diffs
diffs
Jacko
typ17
posted on 18/9/10 at 05:11 PM Reply With Quote
it's a 7.5 then...
thanks
any clues on the ratio?
jacko
posted on 18/9/10 at 05:14 PM Reply With Quote
This may help you
no2
no2
minitici
posted on 18/9/10 at 06:00 PM Reply With Quote
Originally posted by typ17
I think you are looking at the casting number on the case rather than the serial number which should be on a tag on one of the bolts holding on the rear cover.
[Edited on 18/9/10 by minitici]
big_wasa
posted on 18/9/10 at 06:12 PM Reply With Quote
I will take a bet at 3.91
snapper
posted on 18/9/10 at 06:58 PM Reply With Quote
I'll take the bet as I think it will be a 3.64
I eat to survive
I drink to forget
Dusty
posted on 18/9/10 at 07:31 PM Reply With Quote
You can remove the backplate. Empty oil. Give each bolt head a sharp tap with a hammer first (steel in ally corrosion). Diff ratio will be written on gear. You can see if it's a viscous diff. I vote 3.62.
Chippy
posted on 18/9/10 at 10:09 PM Reply With Quote
Being as it's a 93 jobby, it will almost certainly be a 2 Ltr DOHC, so I go for a 3.91, but could be wrong, Cheers Ray
typ17
posted on 19/9/10 at 11:13 PM Reply With Quote
hi,
been out over the weekend.
minitici you were right I was looking at the case casting numer.
It is a 7.5" for sure.
There is a plate on a bolt that has the following:
89GG AA 391
4A OM18
I will open it tomorrow and see who was right
Dan.
posted on 20/9/10 at 01:27 AM Reply With Quote
hi,
89GG AA 391
4A OM18
Providing the plats has no been swapped its a 3.91:1
typ17
posted on 20/9/10 at 05:10 PM Reply With Quote
Finally open.
It's a 3,91...
That will give me 113mph top speed according to ther Gear Calc on the BEC sub Forum.
seventhheaven
posted on 2/12/10 at 12:58 PM Reply With Quote
Sierra Diff
A friendly man at the local ford dealer let me use his microfiche machine and I've managed to get all the part numbers, FINIS numbers, exploded diagrams etc for Sierra, Granada and Scorpios. I'm putting together everything I've found atwww.super7thheaven.co.uk
Hope that helps - It's a work in progress
4wd 3.9 Rover V8 Locost 7 - Super 7th Heaven
phelix
posted on 11/12/10 at 09:09 AM Reply With Quote
Any tips on removing the back plate? Seems v well stuck on.
phelix
posted on 11/12/10 at 05:20 PM Reply With Quote
Never mind; just kept whacking it with a lump of wood (after removing all of the bolts!) and it eventually popped off.
norm007
posted on 4/1/11 at 11:51 AM Reply With Quote
Also the "AA" shows thats its a LSD as well
Something about this, so very wrong.....I have to laugh out loud, I wish I didn`t like this!!!!!!!!!!!!!!
