<<  1    2  >>
Author: Subject: Spencer Ashley Plenum
JeffJeffers
posted on 5/11/10 at 11:48 AM Reply With Quote
I recived a plenum that I ordered from Spencer Ashley.
manifold
manifold
When I bought it he did say it needed a little finishing off so gave me a few quid off. But I noticed last night that none of the tubes inside the chamber have been cut flush is that right?
inside manifold
inside manifold
tomgregory2000
posted on 5/11/10 at 11:51 AM Reply With Quote
tomgregory2000
posted on 5/11/10 at 11:53 AM Reply With Quote
that is sh1t, send it back, you might make 7bhp if your lucky using that
mattyc
posted on 5/11/10 at 12:01 PM Reply With Quote
I have first year Apprentice's that would and make a better job of that. I would send that back and ask for my money back.
MikeR
posted on 5/11/10 at 12:07 PM Reply With Quote
this is why i'm thinking of making my own version and selling them...... just need to get dxf's for the crossflow and zetec inlet manifolds.
mattyc
posted on 5/11/10 at 12:18 PM Reply With Quote
I was just thinking the same thing but I have read some where that the is a science for gaining the maxium BHP from the inlet. If anybody has the measurements for something like this please u2u me.
will121
posted on 5/11/10 at 12:40 PM Reply With Quote
that is shockingly bad (like my spelling) that and the griffin type inlets manifold should be easy to fabricate to a decent standard and with a bit of engineering thought even by fabricating the outer tube in two parts to enable some form of inlet runner incorperating a trumpet, i fabricated mine with a fiberglass plenum. as for inlet design think main areas are length for peak rev's trumpet for flow, getting to deep to look at pulse tuning and think that would be OTT
[Edited on 5/11/10 by will121]
JeffJeffers
posted on 5/11/10 at 01:16 PM Reply With Quote
I didn't think that seemed right.
I can't see it being to hard to make a better job. I could take some measurements off this if that would help someone to make one.
I payed £150 for this thinking that would be cheaper way to get my car running.
mattyc
posted on 5/11/10 at 01:35 PM Reply With Quote
If you could take some for me that would be good.
MikeR
posted on 5/11/10 at 02:08 PM Reply With Quote
i'd like a copy of the measurements as well please (and some photos).
cheers.
big_wasa
posted on 5/11/10 at 02:47 PM Reply With Quote
Yep its crap
What about getting together and getting one cast ?
There is a firm doing one for the x flow, and cosworth amongst others do one for the duratec.
I can take some dimensions of mine ?
DaveFJ
posted on 5/11/10 at 03:10 PM Reply With Quote
looks pretty small? i thought the rule of thumb was 'twice the capacity of your engine' ?
Dave
loggyboy
posted on 5/11/10 at 03:18 PM Reply With Quote
Is it steel or ally?
Those welds look attrocious!
I'd want a lot more discount or a refund!!
FASTdan
posted on 5/11/10 at 03:20 PM Reply With Quote
any pics of the injector side? what does he do for the injector mounting?
presumably they are left like that to try and 'mimick' velocity stacks.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
big_wasa
posted on 5/11/10 at 07:26 PM Reply With Quote
Link
interestedparty
posted on 5/11/10 at 07:54 PM Reply With Quote
Why would people want the measurements if they think the design is cr*p?
big_wasa
posted on 5/11/10 at 08:02 PM Reply With Quote
Its the build quality that is crap, well for the money anyway. The idea works fine. The runners should stick through as per the griffin design but not that much.
i_froloshki
posted on 6/11/10 at 04:32 PM Reply With Quote
Do we have pics from the injector side and measurements?
JeffJeffers
posted on 6/11/10 at 05:30 PM Reply With Quote
Sorry I left it at work and I'm not back till Monday. I'll take pictures then.
cliftyhanger
posted on 6/11/10 at 05:50 PM Reply With Quote
surely the runners need a radius on the end for good airflow?? That would help a fair bit I suspect, though make fabrication harder. Even the old Triumph PI (remember those?) had trumpets inside the plenium. Then again that system was developed by Lucas for F1 cars back in the early 60's so probably had a large budget, even then.
The runner lengths should be failry easy to work out, the jenvey site has some figures for v. high revving motors and a rule of thumb calculation for others max rpm's.
However all this is surely governed buy available space and budgets
big_wasa
posted on 7/11/10 at 09:19 PM Reply With Quote
Image deleted by owner
[Edited on 7/11/10 by big_wasa]
FASTdan
posted on 7/11/10 at 10:32 PM Reply With Quote
What fuel rail and injectors is that?
NS Dev
posted on 8/11/10 at 09:31 AM Reply With Quote
the rail looks like 8 valve 2.0 vauxhall engine (20seh)
no idea what the injectors are!
coyoteboy
posted on 8/11/10 at 10:21 AM Reply With Quote
That first one is a proper shocker!
big_wasa
posted on 8/11/10 at 12:17 PM Reply With Quote
I havnt bought one, I just asked for detailed pics to gauge fitting and that was all I needed to keep my money.
Injectors are the standard end fed bosch type as fitted to the black top zetec. As for fuel rail I dont know what that one is from but the black top one could be used just fine.
I plan on making another after xmas. I was thinking of using a cosi Tb to make the idle controle valve easier.
<<  1    2  >>
