Author: Subject: Smarten up Zetec Cam Cover
The Baron
posted on 21/11/10 at 04:46 PM Reply With Quote
I am just finishing off my Pinto to Zetec conversion (on a tight budget)
Has anyone got any tried and tested solutions to really smarten up a zetec cam cover which is showing its age.
whats the best way to clean it, what is the best paint for it, does it need a etch primer etc....
The big requirement is it needs to be really cheap, but effective....
B
ps, its the early cast ally type.
[Edited on 21/11/10 by The Baron]
austin man
posted on 21/11/10 at 04:50 PM Reply With Quote
Light blasting with soda, etch prime and paint or powder coat again I would have it lightly blased. i have seen 2 silvertops powdercoated both lookes immaculate
posted on 21/11/10 at 04:51 PM Reply With Quote
£20 will see it blasted and powder-coated to look like new!
It's Evolution Baby!
violentblue
posted on 21/11/10 at 05:02 PM Reply With Quote
I stripped mine and polished it.
a few pics of my other projects
will121
posted on 21/11/10 at 05:54 PM Reply With Quote
diswasher to clean it, etch primer + can of top coat, pick out the 'zetec' in silver to finish, other options polish it or crinkle paint it?
speedyxjs
posted on 21/11/10 at 06:22 PM Reply With Quote
That is by far the best 'locost' way to smarten it up. I tried doing it with mine but gave up after 20mins and painted it with alloy wheel paint i had in the garage instead
The Baron
posted on 21/11/10 at 07:36 PM Reply With Quote
The wife is out tomorrow night, so the dishwasher it is
B
skodaman
posted on 21/11/10 at 08:12 PM Reply With Quote
If it's a silvertop solvol autosol a toothbrush and a few hours.
Skodaman
flak monkey
posted on 21/11/10 at 08:20 PM Reply With Quote
Dont get it grit/bead blasted. You'll more than likely end up with grit in your engine.
Soda blast it at home and then get it powdercoated.
If you cant be bothered to blast it, just rub it over with 200 grit paper and then get it powder coated.
Sera
http://www.motosera.com
Paul TigerB6
posted on 21/11/10 at 08:56 PM Reply With Quote
B
You want to do the job really cheap.............. don't get caught then - or this could get very very very expensive for you!!
L5W
posted on 21/11/10 at 09:15 PM Reply With Quote
Here's my effort, same as method as Will121 said. I used etch primer then plastikote metallic blue from Halfuds. After taking off the paint on the raised logos with a bit of wet and dry I went over with clear lacquer. Quite pleased with the result
http://l5w-mk-indy-zetec.blogspot.com/
bob
posted on 22/11/10 at 12:02 PM Reply With Quote
Probably not locost and it wouldnt have to be Lotus but i thought this looked nice.
[img] nice cam cover
nice cam cover
[/img]
bob
posted on 22/11/10 at 12:16 PM Reply With Quote
I went for a degrease and spray option, i used sperex enamel spray from the can and it seems to have lasted ok.
Before
[img] engine in and running 1
[/img]
After
[img] engine over scuttle
engine over scuttle
[/img]
