Author: Subject: What does this do ?
Macbeast
posted on 8/12/10 at 03:19 PM Reply With Quote
What does this do ?
Hanging on the side of my ex Sierra Pinto carb. There seem to be two air pipes and an electrical connector.
I can't find it in Mr Haynes.
What does it do ? Is it necessary? What are the electrical connections ?
carb thingy
carb thingy
posted on 8/12/10 at 03:25 PM Reply With Quote
Is it actually part of or attached to the carb in some way?
Difficult to see in the photo, but it looks like it's not part of the carb, but just hung there because it's convenient?
Does the fuel line run through it?
Macbeast
posted on 8/12/10 at 03:29 PM Reply With Quote
No it's just hanging there.
Don't think there is fuel, just vacuum.
Bluemoon
posted on 8/12/10 at 03:40 PM Reply With Quote
It's probably an electrically operated vacuum valve used to switch things in the carb (normally one end the inlet manifold (i.e. vacuum feed) and the other to a diaphragm actuator on the carbs, for say deceleration emission regulations....
Keep meaning to remove mine on the CVH as the actuator in this case stops the throttle completely closing to reduce VOC emissions snag is in a light weight car it goes into "self drive" mode, as there is to much open throttle!!
Dan
posted on 8/12/10 at 03:59 PM Reply With Quote
What engine/carb is it?
1.6 Emax maybe?
Obvious questions where do the wires go and what happens if you disconnect them?
posted on 8/12/10 at 04:00 PM Reply With Quote
Its a device that sends message to big brother so they know exactly where you are and how fast your going
Guinness
posted on 8/12/10 at 04:34 PM Reply With Quote
Flux capacitor?
russbost
posted on 8/12/10 at 06:29 PM Reply With Quote
I think you'll find it's an anti run on valve . When you switch ignition off it opens an extra vacuum inlet to the carb thus making the mixture too weak to run on - Fords (& others) had big problems with engines running on in those days, an extreme example I watched keep going for nearly 2 minutes (we were timing it!) until we finally gave up & stalled it!
Canada EH!
posted on 8/12/10 at 06:44 PM Reply With Quote
Had one on a 1972 Capri Cologne 2.6, it's a valve that opens on deceleration to weaken the mixture, anti polution device, took it off after warrenty, no ill effects.
Macbeast
posted on 8/12/10 at 07:44 PM Reply With Quote
Russ, I think you've got it
But thanks to everybody for the suggestions, particularly the flux capacitor .
