kensprin
posted on 9/3/11 at 10:39 PM |
Dont get this
Bought one of these and failed. you can put you finger on the end of the fuel output. it just dont seem to have the drive pressue. my cossy cut
out.
Facet Type Silver Top Competition Fuel Pump 4.0-5.50PSI on eBay (end time 04-Apr-11 15:37:50 BST)
p.s here an updated video just before the pump failed.
http://www.youtube.com/watch?v=wTa4qzgCfqw
Chippy
posted on 9/3/11 at 10:44 PM |
That pump is for a carb type set up, your BOB is fuel injection so you need a pump that does three plus BAR not PSI. HTH Ray
wilkingj
posted on 9/3/11 at 10:49 PM |
Maybe its not FUBAR after all... Perhaps you can check the pressure is OK (4 to 5.5PSI), and put back on Ebay, and recover some money. Then get the
correct pump.
Best Regards
Geoff
http://www.v8viento.co.uk
Antnicuk
posted on 9/3/11 at 11:03 PM |
have you fitted that 4 psi to your fuel injected engine?, unless i am missing something, you need a high pressure fuel pump. The pump you have is
supposed to stop if you put your finger over it, a minute needle valve in a carb has to be able stop the fuel flow with that pump. I am surprised
your engine ran at all with that pump as the fuel wouldnt have atomised.
Why dont you use the original pump from the doner car that supplied the engine. Alternatively, you need a reasonable high pressure pump as you
should have between 40 and 45 psi at the fuel rail, not 4 - 4.5psi
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
kensprin
posted on 9/3/11 at 11:14 PM |
Dang! thats where Im going wrong mixing up PSI with BAR, so thats around 40psi. Yes the engine just about ran I thought something wasnt right.
Thanks lads. The guy who sold it me said it will be okay. NOT.
What Facet fuel pumpshould I go for them. I have the stock one here to use was thinking about using it but I will need todo some cutting.
Chippy, Glad your kicking out that much BHP out the boa.
Cheers guys.
posted on 10/3/11 at 12:02 AM |
I don't think Facet make fuel injection pumps, at least I've never seen one. You need something like this
[Edited on 10/3/11 by MikeRJ]
coyoteboy
posted on 10/3/11 at 01:21 AM |
i got a bmw inline pump for £30 quid on the bay. blue one, new
Nitrogeno25
posted on 10/3/11 at 05:36 AM |
Something like this:
NEW Petrol fuel electric pump for BMW 535i, M5 3.5 E28 on eBay (end time 03-Apr-11 10:06:08 BST)
big_wasa
posted on 10/3/11 at 07:28 AM |
use that one to fill a swirl pot and a high presure one like the link above to suply the engine.
cliftyhanger
posted on 10/3/11 at 10:51 AM |
I think the proper bosch cossy pumps are about £100? Probably worth paying for one, I think they are higher capacity than many of the others
cliftyhanger
posted on 10/3/11 at 10:54 AM |
RS Cosworth (Sierra) Standard Bosch Fuel Pump on eBay (end time 11-Mar-11 11:34:07 GMT)
just about a ton.
The cossy ones will deliver about 300LPH, many of the others are less than half that. May (or may not) be important
