Author: Subject: it just gets worse, radiator leak
chrisbeale
posted on 23/4/11 at 04:58 PM Reply With Quote
i was just messing around, getting things running smoother, making sure i had no leaks etc ready for next weekend, when i looked into the nose and saw a few drops of water, hmmm thats weird.
i reached in to the place where i believed it to be coming from and it was wet, sooooo i gave it a little wiggle, well, bubble bubble bubble spirt spirt. oops. i think what ever seal was there is now not there so much, any ideas how to fix this, any compounds?
dont really fancy radweld, even if it worked i feel it sometimes causes more problems than it solves.
it looks prett bodged already, just want to get to stoneleigh without the need to get a new radiator (which im not going to manage now on a 3 day week am i)
any way, hopefully these pics will work. and you'll see the connection
god im a pain.
rad leak
rad leak
rad 2
rad 2
rad 3
rad 3
daniel mason
posted on 23/4/11 at 05:06 PM Reply With Quote
that needs sorting properly by the look of it mate!
bob tatt
posted on 23/4/11 at 05:14 PM Reply With Quote
if its copper and the tail sticking out is brass it can be soldered in, you will need to get it very clean and dry then solder as normal.
Or if its steel tap and die it and get a proper conectot to screw into it plumbers merchants should have something to fit that.
But as above it needs doing properly that looks like bodge central to me.
posted on 23/4/11 at 05:17 PM Reply With Quote
Five minute job to clean it up and solder it in with a blow lamp even if the tail is steel
chrisbeale
posted on 23/4/11 at 05:20 PM Reply With Quote
well,i dug a litte deeper and
i think that was either a strengthener or a little extra seal, but if it was soldered in it wasnt done very well
rad 4
rad 4
rad 5
rad 5
rad6
rad6
will get a big f off soldering iron from work tomorrow and give it a bash
bigger is best.
bob tatt
posted on 23/4/11 at 05:43 PM Reply With Quote
give it a good clean then resolder dont forget to flux the joint up first it will run a lot better.
nice easy fix that one.
chrisbeale
posted on 23/4/11 at 05:47 PM Reply With Quote
phew
