mad4x4
posted on 26/4/11 at 06:22 AM |
Cosworth 24V engine
Just been offered the above engine out of a 2.9 Granada running..... Is it just to big for the MK Indy?
mangogrooveworkshop
posted on 26/4/11 at 07:16 AM |
no it will fit
MakeEverything
posted on 26/4/11 at 07:31 AM |
It'll fit. Cracking engine too.
Kindest Regards,
Richard.
marcjagman
posted on 26/4/11 at 08:11 AM |
NO NO NO it's WAY TOO BIG. but would be great for my XR4x4 you'd better give it to me instead so it doesn't go to waste.
kensprin
I just fitted the 24v bob in my robin hood. It is tight I have about 1.2 inch at the front section of the cam heads to the chassis. I thought the mk
was narrower.
Richards this engine goes like hell and with a beautiful sound track too. I'll take
I'll take a pic of the bay with measurements
mad4x4
posted on 26/4/11 at 08:27 AM |
Might also be able to get the DIFF from the Granada cosworth aswell. It's bolt of flanges so will it be LSD?
Scot's do it better in Kilts.
NeilP
posted on 26/4/11 at 08:32 AM |
Yep - Friction plate LSD...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
jollygreengiant
posted on 26/4/11 at 08:34 AM |
Don't forget to get the ECU and assorted sundries. Then teach the ECU how you like to drive.
posted on 26/4/11 at 08:43 AM |
*Grumpy Mode On*
It may not be too big, but it has NO place in a lightweight chassis like yours! Heavy as a heavy elephant and not even all that powerful!
No one would be interested in it if it wasn't associated with the word 'cosworth'.
All IMHO of course!
(*and sits back to await a long overdue kicking!*)
It's Evolution Baby!
contaminated
posted on 26/4/11 at 09:52 AM |
The BOB is 206 bhp from memory. That's not bad. What does it weigh?
posted on 26/4/11 at 10:12 AM |
I once asked the guy at Boosted (BOB / BOA specialists) and I'm sure it was somewhere in the region of 220kg.
Liam
posted on 26/4/11 at 11:21 AM |
It's not an LSD if it's a bug-eye facelift Scorpio, but an old Granada Scorpio will have LSD.
As for the weight - the resultant car is still gonna weigh plenty less than a Lotus Elise - dont see the problem myself. But somebody will always moan
when there's talk of fitting a big engine.
posted on 26/4/11 at 11:30 AM |
Whilst it may end up weighing (marginally) less than a Lotus Elise, it's worth bearing in mind that a Lotus Elise benefits from being
beautifully balanced due to the mid-mounted engine and all that Lotus know-how.
Stick 200kg up front in a locost type car and you're going to struggle to make it change direction in the twisties.
If, however, you're a suspension set-up guru or you just want to stick a big Ford engine with a bit of Cosworth DNA in it for the sheer hell of
it, then by all means... go for it!
Sorry for daring to have an opinion....
Liam
posted on 26/4/11 at 12:05 PM |
Nowt wrong with opinoins - it's just the 'facts' that are sometimes used to justify them!
A Seven, even with a heavier than usual engine in its position well behind the front axle, with all that lard right at the back - axle, fuel, roll
bar, occupants - is not far off a 50-50 weight distribution anyway. Even my 4WD with a V6 (albeit an ally one) and the front axle is very close to
50-50. So the idea, often put forward, that a big-engined Seven will somehow be some disastrous ditch-finding understeering oil tanker is pretty much
ridiculous. 'Struggle to make it change direction in the twisties'? Seriously? Compared to a Superlight R500 - maybe a little bit.
Compared to almost everything else on the road - no way.
All IMHO of course!
posted on 26/4/11 at 12:46 PM |
Yes, it stands to reason that you should be able to get it to handle better 'compared to almost everything else on the road', but why
settle for that when you could make it handle MUCH better 'compared to almost everything else on the road' simply by not using this
engine and going for something more suitable?
I just cannot see the point in putting a whacking great lump of metal like the BOA / BOB engine into a Seven-style car when there are better suited
engines available for similar money.
The sole (occasional) attraction to this engine is the magical cosworth association. If the same engine existed without the cosworth tag, then
I'd wager that we wouldn't be having this conversation... no one would be interested in using it for a lightweight sports-car build
because it's a big fat asthmatic knacker!
posted on 26/4/11 at 12:50 PM |
... because it's a big fat asthmatic knacker!
And I should know one of them when I see one!
kensprin
posted on 26/4/11 at 07:36 PM |
If it was me I'd put a Honda s2000 in a mk. However the bob has much more torque at the low end. Mk I don't think has the strength. My
robin dose tho its a tank compared to the locost or mk.
