Author: Subject: C20xe adjustment
stevegough
posted on 30/4/11 at 10:39 AM Reply With Quote
C20xe adjustment
At my IVA test, the tester said my engine was running 'lean' and showed me a blanking plug on the side of the air mass meter, said there was an adjustment screw underneath to adjust the mixture - anyone know how to use it? - ie to make the mixture richer, prise out the plug, then turn the screw clockwise? - Do I need to refit the blanking plug?
My engine is running exactly as it was in the Calibra, ie standard injection, manifold and Motronic ECU.
The engine seems to run well, but tends to missfire a little on hard acceleration - could running lean cause this?
Lots of questions in one post, I know, but theres lots of experts out there!
Thanks in advance, guys!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Ben_Copeland
posted on 30/4/11 at 12:00 PM Reply With Quote
c20xe adjustment
c20xe adjustment
There ya go...
[Edited on 30/4/11 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
Ben_Copeland
posted on 30/4/11 at 12:03 PM Reply With Quote
If you want a bigger version you can actually read (resizes too small) i'll email you the piccy...
Ben
stevegough
posted on 30/4/11 at 12:13 PM Reply With Quote
Thanks, Ben - you have U2U.
Luego Locost C20XE.
perksy
posted on 30/4/11 at 04:45 PM Reply With Quote
Lean running could cause your missfire ( aswell as a few other things tbh )
Would be worth getting a CO meter on it if you are going to adjust the mixture though as Too Rich a Mixture can cause problems aswell
stevegough
posted on 30/4/11 at 06:52 PM Reply With Quote
CO on the IVA test was 0.24 as I remember - the limit for my car was 3.5.
Luego Locost C20XE.
