Author: Subject: Type 9, zetec fly wheel
Rob E
posted on 13/5/11 at 08:50 PM Reply With Quote
Hi all
I'm having a few problems with my new starter motor ( not working anymore) I have just fitted a type 9 to a st 170 with 2.0 fly wheel and I've used the lrs707 starter but after a run out the starter was whizzing even when the engine was turned off and then stopped working , so my question is am I using the wrong fly wheel ( should it be the 1.8 with pinto clutch ) or am I using the wrong starter ??
Please help as this is stating to drive me nuts.
Rob
No it's not new I've had it for ages!!!
austin man
posted on 13/5/11 at 09:03 PM Reply With Quote
the starter requires for the zetec is from a either th Dohc or CVH engined Sierra or 2 litre DOHC granada, a standard 1.6 or 2 litre starter requires a 14 mm spacer
Rob E
posted on 13/5/11 at 09:12 PM Reply With Quote
So I would need to put a 14 mm spacer between the starter and the box ??
RichardK
posted on 13/5/11 at 09:20 PM Reply With Quote
If your using a pinto starter then yes, I did it this way
Rich
Gallery updated 11/01/2011
Rob E
posted on 14/5/11 at 06:00 AM Reply With Quote
No the starter is not a pinto one it's the dohc 2.0 starter.
doddy
posted on 14/5/11 at 09:48 AM Reply With Quote
sound more like you had the starter wired up wrong and now its over heated
https://www.ebay.co.uk/str/4x4wheels
Rob E
posted on 14/5/11 at 09:49 AM Reply With Quote
Nope wires all ok , checked and treble checked.
doddy
posted on 14/5/11 at 09:54 AM Reply With Quote
when you say it was wizzing after turn off maybe there is just a problem with the solenoid on the starter as there must have been power going to it somehow
[Edited on 14/5/11 by doddy]
big_wasa
posted on 14/5/11 at 09:58 AM Reply With Quote
If the starter is spinning with the engine of then I would say you have a wiring fault.
How have you wired it ?
Rob E
posted on 14/5/11 at 12:38 PM Reply With Quote
Just got hold of a 1.8 pinto starter and it fits without a spacer and works fine albeit a bit rough and noisy ?? Why does this fit and work ???
Rob E
posted on 14/5/11 at 12:44 PM Reply With Quote
I thought there was only one way to wire it , small wire. ( ignition wire ) goes to the small thread and large battery wire goes to the large thread ( if that all makes sense )
I drove it for a while say about 20 mins then stopped, all fine then went out 10 mins later and about 5 mins into the drive heard a noise stopped and turned of ignition but it kept whizzing so took the neg of the battery and it stopped ??????
posted on 14/5/11 at 01:04 PM Reply With Quote
If it starts making the noise again it would be a good idea to pinpoint the problem, try disconnecting the feed wire from the ignition switch when the problem occurs, if it stop the noise then problem may be with the ignition switch, wiring or if you have fitted one, the starter relay . If the noise is still there and the only way to stop it is to disconnect the battery it sounds like the bendix is engaged with the flywheel ring gear and needs further investigation
[Edited on 14/5/11 by rusty nuts]
RichardK
posted on 14/5/11 at 08:07 PM Reply With Quote
Could it have been a 1.8cvh in which case it would be fine?
keithometune
posted on 15/5/11 at 01:38 AM Reply With Quote
assuming you are not getting a feed to the solenoid, it must be a faulty solenoid i have heard of bosch ones failing like this.
keith
Rob E
posted on 15/5/11 at 07:13 AM Reply With Quote
keith
Even a new one ??
garybee
posted on 18/5/11 at 09:33 PM Reply With Quote
I'm sure all 1.8 petrol Sierras were CVHs.
posted on 19/5/11 at 05:40 PM Reply With Quote
Wrong, some had a 1.8 Pinto and some had a 1.8 desiel
keithometune
posted on 19/5/11 at 11:22 PM Reply With Quote
brand new or reconditioned?
