Author: Subject: Every 3 or 4 weeks I remember why I detest Windows Vista!
posted on 11/7/11 at 05:01 PM Reply With Quote
I have a Dell Latitude D630 laptop - a decent enough little workhorse that's good enough for times when I need portable computing. Originally it came with "Windows Vista Business" installed, but most of the time I swap out the hard disk with one that has Linux Mint installed - the only reason I keep the Vista drive is that I have some software that just won't work on Linux via an emulator such as Wine or VirtualBox (e.g. software for updating my SatNav).
If I haven't used the Linux system for a while I get notification of updates in the message bar. A dialog appears, I confirm, then it takes maybe 1 or 2 minutes tops to do the job, then the dialog closes. End of excitement.
I have just put the Vista drive back in (last in about 1 or 2 weeks ago) and it's just taken me 2 hours to finish the updates! (including 1 lock-up and a warning message on restart). I know Windows 7 is far better, but I'm not prepared to pay that sort of money for an equivalent spec version for an OS I rarely use.
In a similar vein, when I turn it on using Vista it takes anything up to a minute to find my wireless network (sometimes it fails and I have to sort it out manually). If the laptop is on its docking station then the hard-wired network is available, giving greater speed - Vista insists on using wireless.
In Linux I turn it on and within 10 seconds of the system opening I get a message stating that the wireless connection is up and running. If the laptop is on the docking station then the system picks up the hard-wired network immediately, ignoring the wireless.
Aarghhh!
Thank you for enduring this rant - I feel better now... [breathe in... breathe out... breathe in... breathe out... ahhh]
Kwik
posted on 11/7/11 at 05:07 PM Reply With Quote
i know the pain, i moved from vista to linux about a year ago, only thing i miss is the big softwares i used like solidworks, i will need to either change it back or get windows 7 for when i need solidworks again, but until then im enjoying 6 seconds to boot up and trouble free paint free computing
mcerd1
posted on 11/7/11 at 07:50 PM Reply With Quote
stick a copy of win2K on it - simple and solid
(it uses the same drivers as xp so you can still make it work on most things)
posted on 11/7/11 at 08:02 PM Reply With Quote
I have Win2K on the old clunker laptop I use to set up my Megajolt, and WinXP on my VirtualBox installation!
I used to work for a software company that had links to MS, so I tried to make sure that all my software was legitimate - which I've just about achieved. That's another reason for mainly using Linix Mint - all the functionality I want is free...
posted on 11/7/11 at 08:32 PM Reply With Quote
Yesterday it took full days work to install Windows 7 up date it then install anti-virus and office and after all this time windows still can't automatically find drivers for common bits of kit such as USB wireless keys off the net.
Install Mint 11 Katya and all the required software and printer and network drivers straight on to the net and update it takes less than 30 minutes.
[Edited on 11/7/11 by britishtrident]
Ninehigh
posted on 11/7/11 at 11:48 PM Reply With Quote
Maybe you have the wrong Vista, mine's not that bad and my laptop's that slow I can make it lock up by typing too fast
posted on 12/7/11 at 07:06 AM Reply With Quote
Yes, you're right - mine's the one written by Microsoft...
mcerd1
posted on 12/7/11 at 07:48 AM Reply With Quote
even my brother wants rid of vista from his lappy and he hasn't got a clue about computers
to be fair to MS, win7 is pretty good, I've been running it for ages now and the only issues I've had have been to do with old software that can't deal with the 64 bit system (although some of the really ancent stuff actually works perfectly )
I's still rather have an updated win2k, but its a close second on my list (its even overtaken 98SE....)
[Edited on 12/7/2011 by mcerd1]
posted on 12/7/11 at 08:36 AM Reply With Quote
Win 7 is a much better system - it's got the stability and usability that Win2K and XP still have, wrapped up in a much more modern OS. It's even got the good bits out of Vista! (there are a few).
I still can't justify spending money upgrading to Win 7 while I only have to use it about once every 3 or 4 weeks.
mcerd1
posted on 12/7/11 at 10:58 AM Reply With Quote
I'm sure you could dig up a legit copy of 2K or XP for nothing - someone on here is bound to have one left over
(I'm all out at the moment - would have had a few copys of 2k but someone at work binned them )
posted on 12/7/11 at 12:47 PM Reply With Quote
Don't worry - I'm not planning to lose any sleep over this!
It does the job on the odd occasion I have a task for it - I just have to plan to turn it on a couple of hours before I need it, so that it can update itself...
Ninehigh
posted on 12/7/11 at 04:13 PM Reply With Quote
I don't think Vista is as bad as people make out, although I do agree it's really annoying when it asks for permission to run a program you cliked on... or tells me I need to contact my administrator about deleting a folder
mcerd1
posted on 12/7/11 at 06:02 PM Reply With Quote
you can turn that stuff off I think (win7 does alot of that too untill you tell it not to)
posted on 12/7/11 at 06:14 PM Reply With Quote
Even Windows 7 isn't that great it is just not as bad as Vista.
How come just about any modern Linux distro can keep itself up to date, reliable and secure but even a recent copy of windows seems spend anywhere between 2 minutes and 20 minutes everyday updating sometimes introducing more problems than they cure.
nyawton
posted on 14/7/11 at 08:53 PM Reply With Quote
To turn it off
Start>controll Panel>user accounts>User account controll> Drag slider to turn off.
Cant remember exact wording atm but sure ull find it Differs slightly between vista and windows 7.
Windows 7 is great. Not a lot to fault about it
