Author: Subject: bike exhausts with cat built in?
blakep82
posted on 13/6/12 at 10:50 PM Reply With Quote
is there such a thing? do they work with car engines? mine is a vauxhall x20xev, so 2litre, with zx9r carbs, i've got a full 2.5" stainless exhaust system already, but i need to put a cat in, so i might as well shorten the exhaust a bit, as it doesn't fit particularly well round my axle anyway
whats the options? won't put a wanted thread up yet, since i don't have the money just now
doesn't have to be a bike exhaust btw, just they tend to be about the right size and shape
[Edited on 13/6/12 by blakep82]
________________________
Slimy38
posted on 14/6/12 at 07:44 AM Reply With Quote
something like this?
http://www.ebay.co.uk/itm/251052406854
Although it's shaped to fit the confines of the bike.
I think if you look at any bike manufactured in the last five years or so they'll need to meet Euro IV spec, which will in general need a cat.
How about looking at supermini's, VW Fox or similar? They'll need a cat but will only have a limited amount of space to host one.
[Edited on 14/6/12 by Slimy38]
posted on 14/6/12 at 08:01 AM Reply With Quote
Bike engine cats are small, I doubt they would cope with a car engine emissions.
franky
posted on 14/6/12 at 08:39 AM Reply With Quote
You can get a can made with a cat in, bike style that'll bolt on.
JekRankin
posted on 14/6/12 at 10:15 AM Reply With Quote
There wasn't much room for both a cat and a silencer on my car, so I bought a cheap re packable silencer and welded a universal cat inside it.
To do this, I opened up the silencer, chopped out a length of the perforated tubing and welded the cat in place. Hopefully should be good enough for IVA.
Link to my original thread:
Link
Jek
blakep82
posted on 14/6/12 at 10:52 AM Reply With Quote
my exhaust does at the moment go all the way to the back, but its very close to watts link bars (like 5mm clearance) and the silencer on the exhaust is very small, and been repacked at some point in its life, meaning its been cut open and welded shut, but quite badly. its full of holes.
thinking of doing something like this
saw racing ones at the weekend where the exhaust stopped here.
the big bit in mine is just an empty chamber, no packing or anything, not sure what it really does, but if i could fit a good cat and silencer in there, that would be good. need to get a cat really, then see what space i have left.
cheers for the info Jek, might have a go at making my own silencer... perforated tube, big stainless tube, some stainless discs for the ends, packing, and a 90 degree bend should do it. hope ending under the back is ok for iva...
actually i've got an R1 exhaust I could open up and modify. even if i just use the carbon case and end caps?
[Edited on 14/6/12 by blakep82]
loggyboy
posted on 14/6/12 at 10:59 AM Reply With Quote
Did you get '6 pack' and 'battery pack' a bit mixed up?
Mistral Motorsport
blakep82
posted on 14/6/12 at 11:08 AM Reply With Quote
aw crap, does that mean i drank the battery last night?!
just checking luggage space. and its perfect!
b14wrc
posted on 14/6/12 at 11:30 AM Reply With Quote
Fiat coupe turbo has the cat in the front silencer. It's a normal sized can too, I might reuse it on my car initially.
20vt powered rear engined locost
DIY Si
posted on 14/6/12 at 12:25 PM Reply With Quote
If your exhaust is 2.5" all the way through, many bike can won't fit, as they tend to be 2". But that's not to say that you couldn't butcher a couple for the cats, but I suspect a bigger car version will suit your needs better.
Sun Tzu, The Art of War
b14wrc
posted on 18/6/12 at 04:44 PM Reply With Quote
As requested blakep82 photo of Fiat coupe front box with cat built into it. Rubbed down and painted black I reckon it would be ok to start off with.
Loud mind.
Rob
