Author: Subject: Stainless fuel pipe
Nitrogeno25
posted on 21/8/12 at 04:04 AM Reply With Quote
Stainless fuel pipe
I have a lenght of 6m 3/8 stainless pipe that I plan to use as fuel pipe.
Can I use brass compression fittings to connect to rubber hose?
Thanks!
TAZZMAXX
posted on 21/8/12 at 06:44 AM Reply With Quote
It really depends on the wall thickness of the tube. If it is thin wall (20g), then it will have a certain amount of give and will crush slightly to make the compression fitting work. If it is 16g wall then it may work via friction but there's always a chance that it will come loose. If it is the thicker wall tube a twin ferrule (stainless steel) compression fitting maybe better.
[Edited on 21/8/12 by TAZZMAXX]
owelly
posted on 21/8/12 at 07:46 AM Reply With Quote
I used stainless Swagelock pipe and normal copper/brass compression fittings gripped, but soon worked loose. So I used a tube cutter to make grooves in the end of the tube and used stainless worm drive clips to mount the fuel hose directly on to the stainless tube. 6 years running at injection pressure and no problems.
http://www.ppcmag.co.uk
maccmike
posted on 21/8/12 at 08:24 AM Reply With Quote
if the walls too thick you could always use a nut and olive fitting
Nitrogeno25
posted on 21/8/12 at 09:39 PM Reply With Quote
Thank you very much for your replies!
The stainless pipe wall is 1mm. The compressión fittings I have consists of a brass ferrule like this:
pipe being free I will give it a try.
Thanks! again.
[Edited on 22/8/12 by Nitrogeno25]
posted on 22/8/12 at 07:36 PM Reply With Quote
Hydraulics engineer would put a flare on each end for a drink , Some garages may be able to help , I think my flaring kit would do it
dave r
posted on 23/8/12 at 05:36 AM Reply With Quote
brass olives on stainless pipe have caused me lots of problems at work, and we only get water leaking then!!
wouldnt want to risk it with fuel
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
