New Topic New Reply
Author: Subject: Noise level from standard Mk Blade Exhaust
Jim
posted on 21/9/04 at 01:33 PM Reply With Quote
Does anybody know the noise level from a standard Mk Blade exhaust. I have a track day booked and the limit is 105 dB. When SVa'd it was 101 db at 5k.
What rev's do people use for track day static tests?
Jim
[Edited on 21/9/04 by Jim]
Mikey G
posted on 21/9/04 at 01:56 PM Reply With Quote
I showed 102db @7500rpm at Castle combe in august, car is a factory built Stuart Taylor Blade with what seems like a worn out silencer at the mo! you should be OK i would have thought, 105db is quite loud!
Mike
Jim
posted on 21/9/04 at 02:28 PM Reply With Quote
Cheers, at the moment the exhaust (redline race can) can be heard about 1 mile away. Will have to change to old Mk one then for track day
Jim
posted on 21/9/04 at 09:02 PM Reply With Quote
Noise
IIRC ours is a ST exhaust via MK. At SVA first test showed 104Db at 7850rpm when clogging it, it would surely exceed 105Db.
Maybe a bit of packing would come in handy...
HTH
Jim
posted on 23/9/04 at 10:29 AM Reply With Quote
Interesting. where did you get this from?
DEAN C.
posted on 23/9/04 at 07:30 PM Reply With Quote
You didnt mention the twenty minutes of hammering,shaping and of course the cursing .Mainly about the plonker doing the emissions tests admittedly!
DEAN.......
Once I've finished a project why do I start another?
Jim
posted on 25/9/04 at 12:30 PM Reply With Quote
Been to Mk to inquire about the inserts. Just want to say thanks for the time and the metal tube
Excellent service as usual
Jim
New Topic New Reply
