New Topic New Reply
Author: Subject: Upgrading to wilwood on the front
ceebmoj
posted on 17/12/12 at 11:35 AM Reply With Quote
My christmass present this year is going to be upgrading the car to use wilwoods on the fount. I run the ford cortina upright and a 13" wheel. Do people recommend sticking with the solid disk or going vented. the car is a BEC and mostly used on the road.
ElmrPhD
posted on 17/12/12 at 12:00 PM Reply With Quote
Superlight (BEC) cars should avoid heavy, ventilated discs. Out "there" at the wheels is the most important location to minimize (unsprung) mass. Well, theoretically, the tire is the most important place due to rotation effects, but there's often not much one can do about that.
I would go further and have the discs drilled and/or grooved for weight reduction and better cooling.
Steve, in the NLs
adithorp
posted on 17/12/12 at 12:01 PM Reply With Quote
Stick with solid discs. I've yet to have any fade from mine either on track or nailing it down Alpine passes (which is probably the toughest test you can do to brakes). Don't go for the Wilwood Smart pads though; Get some Mintex 1144's in stead as they have much better feel.
http://jpsc.org.uk/forum/
ceebmoj
posted on 17/12/12 at 12:31 PM Reply With Quote
Thanks for the feed back and for once it looks like every one agrees as well, which is a bonus.
Johneturbo
posted on 17/12/12 at 12:42 PM Reply With Quote
I've got solid discs with some groves that came with the kit
i hardly use the brakes on the road with the amount of engine braking you get from a BEC
infact my brake lights hardly come on due to having a hydraulic switch (must brake harder)
Benzo
posted on 17/12/12 at 12:52 PM Reply With Quote
again.. no need for vented discs on a BEC.. heavy and youd never get them up to temp.
TimC
posted on 17/12/12 at 01:27 PM Reply With Quote
I tend to agree with the first statement, but interesting that the most successful front-engined RGB car ever uses vented front discs which suggests that your second statement is unlikely to be true.
coyoteboy
posted on 17/12/12 at 01:37 PM Reply With Quote
It's pretty hard to assess what driving conditions a car is going to see in order to estimate what heat dissipation you're going to need. There's a ~4kg per corner difference between some vented and some solid discs, which is a lot, but if you have to re-design uprights/brakes when you find you've under-cooked the rotor design you're more tempted to go larger I can tell you!
With something that the swap is fairly simple, I'd be less worried about staying small.
mark chandler
posted on 17/12/12 at 02:05 PM Reply With Quote
Mine has vented discs, hammering it around the track and they still stay cool, when I get up the energy I will swap out for none vented.
ceebmoj
posted on 17/12/12 at 02:19 PM Reply With Quote
As keeping the unsprung weight down seems to be the most important thing. Has any one drilled there own disks? On Loco's CB500T Cafe Racer build diary. He prints out a patten and then drills the disks. As far as I can see it should not be to hard to make up a patten for cortina disks and do the same as the disks below.
http://www.premiermotorsportdevelopments.co.uk/cortina-ultralight-brake-discs---18kg-saving-200-p.asp
Benzo
posted on 17/12/12 at 02:30 PM Reply With Quote
Those discs are exactly what i'm after for my setup, does anyone else do them? i cant bring myself to Pay a 1/3 of the cost of the item just for postage to NI when it should be free postage like the rest of the UK.
ceebmoj
posted on 17/12/12 at 02:58 PM Reply With Quote
Why not follow this guide How to drill youer brak disks
Benzo
posted on 17/12/12 at 03:09 PM Reply With Quote
Well I need discs as well so I may as well buy some pre drilled!
* they did me a deal on the postage so ive gone for the ones listed with the 1.6kg saving.
[Edited on 17/12/12 by Benzo]
filemon
posted on 23/12/12 at 02:35 PM Reply With Quote
I have had home made drilled discs in my Skoda rally car some time ago. It worked perfectly, it didn't bent or crack cause of heat. I have coppied Zimmerman brake discs hole pattern. I'm going to do the same upgrade with my Haynes Roadster brake discs.
ceebmoj
posted on 23/12/12 at 10:13 PM Reply With Quote
Please can you post some pictures when you get them.
Benzo
posted on 23/12/12 at 10:23 PM Reply With Quote
Should be here tomorrow or Thursday!
ceebmoj
posted on 30/12/12 at 07:18 PM Reply With Quote
Have the disks arrived? If so can you post some pictures?
Stott
posted on 30/12/12 at 08:02 PM Reply With Quote
Just too add and agree with TimC I've got willwoods with mintex 1144s with vented discs and on short tracks on slicks they get too hot and needed ducting adding to them which solved it.
This was hard use though so I can't see solids being a problem for anything but the most extreme use.
Benzo
posted on 30/12/12 at 11:49 PM Reply With Quote
I haven't received them yet :-/
Benzo
posted on 7/1/13 at 11:21 AM Reply With Quote
Discs finally arrived today - 1.8kg saving version.. they certainly feel much lighter..
Saves me having to send them off and get them skimmed & Drilled.
[Edited on 7/1/13 by Benzo]
ElmrPhD
posted on 7/1/13 at 11:30 AM Reply With Quote
That's too cool!
So:
- is that 900 g per disk or 1.8 kg per disk?
- what did they cost?
I might do the same if it's affordable.
Well done!
Steve, in the NLs
Benzo
posted on 7/1/13 at 11:54 AM Reply With Quote
Originally posted by ElmrPhD
That's too cool!
So:
Well done!
Steve, in the NLs
I assume 900g per disc, 1.8kg combined..
The discs came from..
Iain
ceebmoj
posted on 7/1/13 at 12:39 PM Reply With Quote
Its probably just the photos, but the swept patten of holes on that disk don't seam to overlap. I was under the impression that they should.
New Topic New Reply
