Author: Subject: How do you fit VAG rear calipers
filemon
posted on 7/1/13 at 06:42 PM Reply With Quote
Hi guys,
I got question to guys who have fitted VAG calipers to their vehicles.
As I want to keep weight as low as it is possible I want to put those alloy calipers to my Haynes Roadster.
But got few questions.
Do you use original sierra carriers and put VAG calipers onto it, or do you use also VAG carriers.
I have trial fitted VAG caliper with sierra carier, sierra pads and disc, but I'm not very happy with this set.
Can you please advise if it is correct and would it work correct, or should I fit it with VAG carriers.
Also caliper comes into contact with arms on my 15' alloys. This happens because of caliper sticking about 1,5cm over carrier and over brake disc level (see photo nr.2). There is no problem with 16', but I would like to have possibility to change wheels between 15 and 16 (for everyday use and for trackdays).
I also have standart sierra set, but it is a bit heavier.
Some photos:
Slimy38
posted on 7/1/13 at 06:56 PM Reply With Quote
I have those calipers on my SEAT Toledo as standard fit, and they look pretty much spot on to me?
With regards to the 15" wheels, normal practice on SEAT is to use a 10mm spacer between disc and wheel, not sure whether that's an option here? You might need longer studs, and I guess you'll need to make sure it still fits under the wheel arch?
Silly question time, while you're saving weight on the caliper, aren't you then gaining weight by having to use 15" or 16" wheels?
fregis
posted on 7/1/13 at 07:09 PM Reply With Quote
i have same idea, use only caliber and left sierra carriers
also should fit alfa romeo 156, volvo v40, mitsubishi carisma, opel astra/zafira caliber, try them
More choice can be found here brakepartssuperstore
[Edited on 7/1/13 by fregis]
Never be afraid to do what you are insolvent, remember: amateurs built the ark - Professionals built the Titanic.
Ben_Copeland
posted on 7/1/13 at 07:14 PM Reply With Quote
I've got them fitted to my haynes roadster.
I used the VAG carriers and the cosworth solid disc. Fits under my 15s ok, but mine are et16 offset.
Ben
Locost Map on Google Maps
Enter Your Details Here
filemon
posted on 7/1/13 at 07:26 PM Reply With Quote
As it is Locost I'm trying to make it as locost as possible. As I already got some 15' and 16'wheels with 4x108pcd, so I want to use it. Also rear lower wishbone won't fit in 13 or 14 wheel and I don't want to make wishbones once again.
[Edited on 7/1/13 by filemon]
filemon
posted on 7/1/13 at 07:55 PM Reply With Quote
And does VAG carriers fit plug&play to sierra bearing cover or do you have to make some custom brakets?
Ben_Copeland
posted on 7/1/13 at 08:13 PM Reply With Quote
They fit fine, the hole spacings identical
Ben
filemon
posted on 7/1/13 at 08:55 PM Reply With Quote
That is great info, Thanks, I will check it tomorrow, when I get my VAG carriers.
mcerd1
posted on 8/1/13 at 08:29 AM Reply With Quote
I doubt it, the spigot in of the sierra hub only sticks out 11mm past the disc, so not enough to locate the wheel or fit a hubcentric spacer (most of them need at least 15mm)
you'd be better off with 20mm hubcentric spacers or even better wheels with the correct offset...
