Author: Subject: Help! I cant get the propshaft off the sprocket adapter!!
Sloan85
posted on 7/4/13 at 10:48 AM Reply With Quote
I need to take the sprocket adapter off as there is too much movement on the splined shaft (I think I need to add a washer). I have undone the 4no bolts holding the propshaft to the sprocket adapter but the two are stuck together. How can I separate them? Tried WD40 and hitting the edge of the propshaft with a hammer and screwdriver but the two just wont separate.
Any suggestions??
Cheers!!
Sloan85
posted on 7/4/13 at 10:58 AM Reply With Quote
Sorted it.
If in doubt, use a bigger hammer!!
NigeEss
posted on 7/4/13 at 11:00 AM Reply With Quote
I'd be looking at a very thin chisel, or a wallpaper scraper hammered into the join.
omega 24 v6
posted on 7/4/13 at 12:22 PM Reply With Quote
While its off drill and tap a couple of 6mm holes. Then you can then screw bolts into them in the future to seperate the two halves.
posted on 7/4/13 at 12:33 PM Reply With Quote
Put it in a low gear and push the car rocking it backwards and forwards.
posted on 7/4/13 at 03:04 PM Reply With Quote
Put the brakes on and start the engine
:{THC}:YosamiteSam
posted on 7/4/13 at 05:22 PM Reply With Quote
rubber mallet
or hb on - rock the car in gear?
