<<  1    2  >>
Author: Subject: V6 ITB throttle linkage ideas and help
DIY Si
posted on 6/7/15 at 03:30 PM Reply With Quote
Originally posted by Angel Acevedo
No comments have been made on gears.
A main gear in between the carbs would address counter rotation.
The only issue would be fabrication.
Gears would allow customizing pedal to Throttle opening ratio.
I have no formal engineering background so this may be a daft idea...
Or genius...
HHHH.
Hope this helps.
AA
Whilst technically a good idea, as it gives perfect 1:1 motion if done right, the gears wouldn't easily fit as the banks are off set and a fair distance apart. They could possibly be laser cut to avoid the fabrication issue though......
Sun Tzu, The Art of War
Badger_McLetcher
posted on 6/7/15 at 04:56 PM Reply With Quote
Gears are one option I considered, but as Si has said there's manufacturing issues and it's beyond my capabilities without farming it out. My alternate option is to mount a bearing on a plate each end and run a lay shaft down the middle with cable wheels on each end of the shaft to link with the existing ones on the throttle bodies. The actual linkage from the pedal would then go to a third cable wheel in the middle of the lay shaft.
Simpler than it sounds, and whilst I am confident I can make it myself the twin cable set up is even simpler and hopefully easier to make!
If disfunction is a function, then I must be some kind of genius.
Benzo
posted on 28/8/15 at 12:24 PM Reply With Quote
Found this thread useful for a project I'm working on, for anyone else this may help.
Found a great supplier for Bellcranks, linkages etc etc.
Ive this all in one Bellcrank, cable holder, throttle stop, spring device with proportional throttle opening
Its on its way from Australia to me now now.
https://www.efihardware.com
This will be mounted in the V of the V8 to convert from FlybyWire to Manual cable opening.
[Edited on 28/8/15 by Benzo]
<<  1    2  >>
