Author: Subject: [Wanted] Sierra 7" Diff 100mm Flanges
ManuFromParis
posted on 4/3/14 at 10:47 AM Reply With Quote
Hi there,
I'm in the process of rebuilding a 7" 3.92 diff, putting a LSD in there, but I miss the 2 100mm Flanges, as there was none when I purchased this diff.
I assume these Flange are standard from all other models. Please tell me if I'm wrong.
EDIT : I'm looking for 3.62 Open Diff Flanges to complete the one I'm taking parts from. (please read further)
BTW, anyone know where to buy new circlips for that ?
This is it :
"Open" Diff :
[Edited on 4/3/2014 by ManuFromParis]
jacko
posted on 4/3/14 at 10:55 AM Reply With Quote
The lsd sierra diff has different out put shafts to a open sierra diff
The lsd shaft is longer on one side
Jacko
ManuFromParis
posted on 4/3/14 at 11:02 AM Reply With Quote
Thanks, I just read that post confirming that.
http://www.locostbuilders.co.uk/viewthread.php?tid=167125
I guess I'm after LSD Flanges, then.
mcerd1
posted on 4/3/14 at 11:09 AM Reply With Quote
if you are fitting a ford LSD then yes you'll need the unequal length flanges - these could be very hard to find unless you buy a complete LSD
if you are fitting an aftermarket LSD (such as the quaife ATB) they mostly seem to use the equal length ones from the open diff's (and modify them to use snap rings instead of circlips)
[Edited on 4/3/2014 by mcerd1]
ManuFromParis
posted on 4/3/14 at 11:21 AM Reply With Quote
Eventually, I'll fit a Ford LSD from a complete Diff (that needed rebuilt) but I expected I could refit all remaing parts to have a 3.62 open diff for sale.
But I just realised that I'll use the unequal Flanges from old 3.62 on my project then I correct the Add : I'm looking for equal length Flanges for a 3.62 OPEN diff !!!
I'll correct first post
Sorry for confusion.
peter030371
posted on 4/3/14 at 01:28 PM Reply With Quote
I might have some.....my diff is off being rebuilt at the moment and my bolt on shafts flanges are being replaced by Quaife parts. When I get the diff back I will see if the old flanges are what you are after and let you know
ManuFromParis
posted on 4/3/14 at 01:52 PM Reply With Quote
Great !
Looking forward to it.
peter030371
posted on 21/3/14 at 07:20 PM Reply With Quote
Are you still after these as I have a pair now that I no longer need?
ManuFromParis
posted on 24/3/14 at 01:16 PM Reply With Quote
yes, peter --> U2U
