Author: Subject: starter motor ST170 with RS2000 bellhousing.
ttbiker
posted on 10/2/15 at 01:43 PM Reply With Quote
Hi I've got an ST170 engine with 1.8 flywheel RS2000 bellhousing and I want to have the starter motor on the inlet side of the engine, does anybody know what starter I need?
Cheers.
[Edited on 10/2/15 by ttbiker]
Dick Axtell
posted on 10/2/15 at 05:08 PM Reply With Quote
Starter motor
So which side is your inlet? I have a Ford-fitting starter motor for LHS mounting, on to the appropriate bell-housing.
ttbiker
posted on 10/2/15 at 05:42 PM Reply With Quote
The inlet is on o/s or on the right as you sit in the car.
posted on 10/2/15 at 06:51 PM Reply With Quote
With the 1.8 flywheel you need a dohc or cvh type off a Sierra.
Theres one for sale in the for sale bit..
http://locostbuilders.co.uk/viewthread.php?tid=196267
posted on 10/2/15 at 07:03 PM Reply With Quote
I think if you fit a DOHC or CVH to the OS it may be possible to fit it with the solenoid at the bottom provided you have clearance?
posted on 11/2/15 at 05:32 PM Reply With Quote
Yep, the starter on the drivers side will have the solenoid underneath pointing away from the engine.
ttbiker
posted on 12/2/15 at 06:06 PM Reply With Quote
Thanks for all the information guy's..
