johnemms
posted on 10/4/15 at 06:17 PM |
DanSt Manifold R6 Bike Carbs
Called DanST engineering yesterday, ali manifold with 40mm fitting kit arrived 1st class post today..
Stuck my Ebay R6 Carbs on .. Started first time
Took it round the block - running lean..
Stuck some match sticks in the air correctors - (if you squint & look you can see them) - AFR almost perfect ..
Mains have 155's - AFR's 12.5 to 13.5 even at WOT ..
Goes well - worn Yoko's stuck like glue - fab to be out n about again
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
