Author: Subject: Zetec 5yr layup, sticky valves?
Slater
posted on 18/8/15 at 07:29 PM Reply With Quote
Hi, i am just trying to get my 1.8 zetec silvertop running after a 5 yr layup, when I turned the main crank by hand it stopped after 1 turn and wont go any further, could this be a sticky valve? Is the zetec an interference engine? If so how do i fix the sticky valves?
I dont want to attempt to start it or even turn it over on the starter motor till this is solved.
posted on 18/8/15 at 07:40 PM Reply With Quote
Do the cams rotate? Was the engine laid up with oil down the bores? It might be worth taking the cam cover off and checking for any clearance between the cam and followers, any clearance might indicate sticking valves. If you find any sticking valves it might free off with a few clouts with a hammer and soft drift on top of the valve after removing the cams before removing the head.
posted on 18/8/15 at 08:12 PM Reply With Quote
Take the plugs out sounds like hydraulic lock.
kingster996
posted on 18/8/15 at 08:17 PM Reply With Quote
Definitely an interference engine. I have 16 bent valves that will swear to it!
I used to be indecisive, but now I'm not so sure
Slater
posted on 18/8/15 at 09:25 PM Reply With Quote
Thanks Rusty Nuts! Will try that tomorrow, I put a little oil down the bores before storage and some more today, the plugs are all out so its not hydraulic lock.
posted on 19/8/15 at 05:17 PM Reply With Quote
If you do have to hit the valves make sure the pistons are down the bores to stop valve to piston contact
Griff51
posted on 20/8/15 at 06:02 PM Reply With Quote
Definitely an interference engine, Silver tops are notorious for lifters not draining down and leaving valves open.
One that has been standing that long, a couple of valves remain open and is probably corrosion on the stems.
Don't forget to throw the cam belt away!
