Author: Subject: Engine painting (just qualifies in this topic)
chris68
posted on 26/9/15 at 09:53 AM Reply With Quote
Just after opinions for painting engine (block - cast iron; head - cast alloy). What products have people used? Spray/brush? How long lasting is this type of finish likely to last?
snapper
posted on 26/9/15 at 11:03 AM Reply With Quote
It's all in the preparation, must be clean and oil free or paint won't stick
I've used spray engine enamel, break calliper paint and smoothright
I eat to survive
I drink to forget
Nickp
posted on 26/9/15 at 12:39 PM Reply With Quote
Hammerite or Smoothrite works well and lasts too, but as above must be really clean.
sdh2903
posted on 26/9/15 at 12:56 PM Reply With Quote
I thought I'd give the por15 engine enamel from frost a go. It's not really any better than hamerite smooth really although I can't comment on longevity. It did cover well but as previously said all rests on the quality of the prep.
Apologies for the crap phone pic
Engp
Engp
posted on 26/9/15 at 02:03 PM Reply With Quote
Degrease, derust prep prep... Hammerite.
I spent ages getting all the crap off with diesel, then loads of cillit bang and a rotary wire brush in the grinder to get all the rust and other crap off.
2 coats of smooth hammerite does the trick. That's because once you've bolted all the ancilleries back on you can we yove wasted hours of live doing something you can't see. Bit like painting diffs.....
So a bright colour will give it the lift!
chris68
posted on 26/9/15 at 02:26 PM Reply With Quote
So Smoothrite/Hammerite is man enough to take the heat?
Nickp
posted on 26/9/15 at 02:32 PM Reply With Quote
Yep, even Guy Croft uses it on his screaming Twin Cams
Paul Turner
posted on 27/9/15 at 06:01 AM Reply With Quote
I used Halford engine enamel on a Zetec 14 years ago. Cleaned the block to ensure no grease before starting and cleaned off all flaking rust. The paint is much better flowing than smoothright and left a superb finish. Still got the engine as a spare and it still looks like it did when I painted it.
chris68
posted on 27/9/15 at 08:56 AM Reply With Quote
Just had a look on the Halfords website and they still do an engine enamel. But I wonder if it is as good as what you used 14 years ago what with all the changes in paint chemicals over recent years? Still it is reasonably priced and seems to be described as 'thin' so will flow better than Smoothrite.
Irony
posted on 27/9/15 at 06:34 PM Reply With Quote
I think the heat of the block bakes all paint to rock hardness. There are a couple of people on here who swear by simple gloss house paint. I used jotamastic 87 followed by hardtop flexi from Shepherd marine. However I had from painting the chassis. I would think any hi temp paint would be okay.
beaver34
posted on 28/9/15 at 05:53 AM Reply With Quote
always just used normal car paint in a tin, works fine if area is clean and grease and oil free
cr500dom
posted on 16/10/15 at 12:38 PM Reply With Quote
I Just use 2pack, the temps that the outside of a block get to are not that great anyway.
40inches
posted on 16/10/15 at 01:39 PM Reply With Quote
I used Halfords spray Silver, brush Satin Black engine enamel. The black went on easily without brush marks
loggyboy
posted on 16/10/15 at 09:02 PM Reply With Quote
Someone posted about this stuff before and I thought it looked really good.
http://www.frost.co.uk/vht-black-wrinkle-finish-310ml.html
Edit
Found the thread I was thinking of http://locostbuilders.co.uk/viewthread.php?tid=189862
[Edited on 16-10-15 by loggyboy]
Mistral Motorsport
